1989 f250 c5 axles 10.25 differential with posi
Old 04-13-2016, 06:17 PM
Kyle Campbell's Avatar
Kyle Campbell
Kyle Campbell is offline
Well took my truck out the other day. When I'm turning left or right you can feel and hear a clunk in the rear end. Only does it when turning. Could it be the spyder gears or the posi-Trac unit ?
Old 04-14-2016, 12:31 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Mist likely the positract. Change the oil and add friction modifier.
Old 04-14-2016, 03:49 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I would check to make sure your axle flanges are tight, and that your leaf-spring u-bolts, shackles, etc..are all still tight.
The limited slip is a set of clutches, and I can't really see how they'd make a clunk unless something went really bad.
kenpobuck
08-11-2011 06:27 PM
Sbrown
03-18-2010 01:16 PM
tkclary
Offroad & 4x4
19
01-31-2007 01:26 PM
fcfirefighter05
1999 to 2016 Super Duty
04-12-2006 05:06 PM
Halibut4
09-28-2003 05:38 AM
Quick Reply: 1989 f250 c5 axles 10.25 differential with posi
