1978 - 1996 Big Bronco
biug "clunk" starting out
Old Aug 13, 2003 | 01:53 PM
jrcsez's Avatar
jrcsez
Angry biug "clunk" starting out
My 96 Bronco 4x4, 5.0 (love the big bronco) gives a "clunk" that is heard and felt about one second after taking off from any stop. A good Transmision guy said it wasn't "lash" in the diff because it is under pressure sitting in drive at a stop-start up again and "clunk"--all 4x4 functions work.any ideas??
Old Aug 13, 2003 | 01:56 PM
Kemicalburns's Avatar
Kemicalburns
i would say U joint is going out. climb under there and see if there is any play in the driveline.
late
Old Aug 13, 2003 | 03:53 PM
VIBR8R's Avatar
VIBR8R
You can find this posted many, many,many times throughout this site. More than likely it is the slip-joint in the middle of your rear drive shaft. take it apart, clean and regrease it. Put it back together, problem solved. I posted this same question a while back and this is what i was told. the problem is now fixed might have taken me about 45 Min.
