6.0 Fan Feedback
Old Apr 12, 2016 | 05:37 PM
88david's Avatar
88david
6.0 Fan Feedback
My 6.0 is showing a 528 code, no fan feedback. I hear the fan kick in strong at 210 degrees and then cuts off a 192. Is the fan clutch needing replaced or is that how the fan works? This is when I am towing my 5th wheel and the outside temp is round 70 degrees. Oil temp is running 215 and never runs more than 15 degrees over coolant temp.Any Info?
Old Apr 13, 2016 | 09:07 AM
mhoefer's Avatar
mhoefer
Check the 3 wire pigtail on the shroud for damage. It could be the coupling, it could be the harness is damaged. It sounds like you fan is coming on early to me, I don't hear mine until 217 ECT. But the best way is to read FanVAR on an SG2.
samsdad02
Nov 27, 2014 08:30 AM
dr103
Feb 9, 2012 06:15 PM
dr103
Jan 26, 2012 11:14 PM
kyhunter
May 24, 2007 11:25 PM
