Turned the key and BLAM!
Old Apr 11, 2016 | 07:12 PM
Coastal68's Avatar
Coastal68
Ran some errands in the truck, drove it for about 30 minutes then left it in the parking lot for about an hour and a half, maybe more. When it's been sitting that long I choke it and it stars right up without any pedal, so I did that. Cranked right up, as usual, but it backfired through the tail pipe as soon as I hit the key. Loud, sounded like a pistol shot.
Ran fine after that but I noticed as I drove back through my neighborhood a very short chirp coming from under the hood.
Sounds like it's definitely one cylinder making the noise and it only happens at cruising speed - light on the gas not too fast.
I checked the compression: 1)149, 2)132, 3)59, 4)132, 5)132, 6)130, 7) 130 8)35. Nothing new.
My next move is going to be removing the valve covers and looking for loose or bent push rods.
Any advice would be appreciated.
C
Old Apr 11, 2016 | 07:36 PM
351Cleveland C4's Avatar
351Cleveland C4
59 and 35? Not 159 and 135?
Old Apr 11, 2016 | 08:31 PM
Coastal68's Avatar
Coastal68
Yep, 35 and 59.
Old Apr 11, 2016 | 08:37 PM
abe's Avatar
abe
Originally Posted by Coastal68
Yep, 35 and 59.
Nothing new? That ain't good!
Old Apr 11, 2016 | 08:42 PM
Coastal68's Avatar
Coastal68
No, it's not, but they are worse than I thought they were. I have been holding off on any major engine work until I can afford the time and money to put a crate 390 in it. I may go ahead and replace the heads, though.
Old Apr 11, 2016 | 08:50 PM
351Cleveland C4
With those numbers, I say forget the back firing problem and do the whole thing. Rebuilding might be cheaper than a crate, then you'd also know everything in it.
Old Apr 11, 2016 | 09:02 PM
Coastal68's Avatar
Coastal68
Well, yes. That's where I'm leaning now.
I should clarify; this is a truck that sees between 50 and 100 miles of driving a week. With a new house and lots of work to catch up on, I'm having to put off all the things I would like to do to it probably until the Fall.
My main concern at this point is seeing to it that the engine doesn't self destruct before I can either rebuild it or replace it.
Old Apr 11, 2016 | 09:30 PM
351Cleveland C4
Gotcha. Well in that case, I think you're on the right track with checking the valve train.
Old Apr 11, 2016 | 10:11 PM
Don Naslund's Avatar
Don Naslund
I would hook up an air line to those cylinders that are low and apply air pressure to see where the compression is leaking. If you hear air leaking into the carb, its the intake valve. If it is leaking into the exhaust, exhaust valve. If leaking into the oil pan, bad rings or broken piston.
Old Apr 11, 2016 | 10:56 PM
BobbyFord's Avatar
BobbyFord
I'm betting there are bent pushrods. Pull the valve covers.
Old Apr 11, 2016 | 11:05 PM
Coastal68's Avatar
Coastal68
I took off the valve covers, spun the rods around. Everything looked fine. Ran the engine for a few minutes and watched them, revved it up a bit listening for any noises - nothing. I don't know what else to look for.
One thing, though; the thing floods when I shut it off and the engine is hot. Normally it just evaporates after 45 minutes or so but maybe some gas got dumped into the exhaust.
Old Apr 11, 2016 | 11:38 PM
351Cleveland C4
Very possible. My truck will pop hard out the pipes like that sometimes when it's cold. Scares the hell out of anyone next to me, and I think it's funnier than hell! Hahaha
Old Apr 11, 2016 | 11:39 PM
JEFFFAFA's Avatar
JEFFFAFA
Were the rocker arms on the two low cylinders moving the same travel (lift) as the other cylinders?
That flooding problem has to be addressed soon. Flooding like that can cause carb/engine fires. Or gas in the oil. Too much gas in the oil will wipe bearings.
Old Apr 11, 2016 | 11:48 PM
Coastal68's Avatar
Coastal68
Don't know. Would have to check again. Why?
Old Apr 12, 2016 | 12:10 AM
JEFFFAFA's Avatar
JEFFFAFA
As an example lets say the intake valve rocker is moving but not as much. Less lift and/or lift time equals less the piston going down can suck air in that cylinder to create good compression test numbers.
