E brake problems
Old Apr 10, 2016 | 04:41 PM
DanielT28's Avatar
DanielT28
E brake problems
Pushed e brake. Something popped. Inspected all the Cables none broke. Suspecting it's the brake pedal assembly.
Any ideas on what to look for ?
Old Apr 10, 2016 | 11:47 PM
dlragalie's Avatar
dlragalie
Take a peak under the rear rotors, see if anything is jiggly or weird back there (the e-brake pads live under the rear brake rotor). My ebrake was completely locked (from rust) in the unengaged position (could not even get the pedal to move). An afternoon, a deadblow hammer, and 2 cans of PB blaster later, i now have parking brakes that are almost better then my normal brakes.
Old Apr 11, 2016 | 11:14 AM
DanielT28's Avatar
DanielT28
I think it's the e brake pedal. Doing research. As I pressed something popped sounded like in the cab. I've read there's s pulley somewhere on the lever that the rivets break on
Old Apr 11, 2016 | 08:59 PM
DanielT28's Avatar
DanielT28
I believe I found the problem. Spring snapped. Don't know if I can buy just spring or whole assembly
Old Apr 11, 2016 | 09:00 PM
DanielT28's Avatar
DanielT28
Old Apr 11, 2016 | 10:49 PM
ebbnflow's Avatar
ebbnflow
I would look for the whole assembly in a local boneyard.
Old Apr 12, 2016 | 01:09 PM
retiredsparky's Avatar
retiredsparky
It is not repairable. The junkyard is the way to go. That spring is what locks up the ratchet mechanism that holds the cable tight which keeps the e-brake locked.
Old Apr 12, 2016 | 01:32 PM
DanielT28's Avatar
DanielT28
Yeah. I just ordered a new one. Picking it up tonight. I'd rather just go with a new one. Local junk yard are in Portland or. So is north side ford. So I'll just go there. Skip the hassle of broken glass. Spider webs. Dust. All that. Guess I'll be missing out on the adventure of it too.
I will say I have been very happy with north side ford in Portland. They are usually about 15% cheaper then my local dealer and they have a bigger inventory. I have used them about 5x for OEM parts and the salesman said they would knock 30$ off the price. Pretty sweet.
gawent
Sep 11, 2012 05:49 PM
briandrex
Nov 25, 2007 10:33 AM
ken selvy
Nov 7, 2007 07:26 PM
Dwights
Jan 15, 2004 05:26 PM
Jason 88F150
Mar 25, 2002 07:51 PM
