Transmission Chatter
Old Apr 9, 2016 | 11:30 PM
siouxlini's Avatar
siouxlini
2010 F150 - 5.4L
I encountered a disturbing chatter/buzzing noise while towing recently.
I have not towed a lot with this truck but recently bought a 8.5x18 enclosed car hauler and have towed the trailer about 3000 miles so far. Twice I have experienced a chattering noise from the transmission under very specific conditions. Was traveling on a long flat road at about 70 MPH in 5th gear at about 2100 rpm when it started. If I let off the noise would instantly go away. If I accelerated and went into 4th the frequency and tone of the chatter would not change with either RPM or speed, however, when I let off it would go away.
It is almost impossible to reproduce because it has to be flat. It did once start to chatter in 4th when I was pushing a strong headwind at about 70 MPH and 3000 RPM.
Any ideas??
Old Apr 10, 2016 | 05:37 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
How many miles are on the truck?
Old Apr 10, 2016 | 07:38 AM
awq134's Avatar
awq134
are you positive it's the transmission and not further forward?
Old Apr 10, 2016 | 11:12 AM
siouxlini's Avatar
siouxlini
115,000
I'm not certain where the noise is coming from. Seems like it's coming from that area and when you let off and let it go up to 6th it stops right away.
Old Apr 11, 2016 | 05:05 AM
tseekins's Avatar
tseekins
Originally Posted by siouxlini
115,000
Has the transmission service ever been completed yet? Yes, the owners guide says that it ok to do a 150K mile service but may be she's ready now.
Old Apr 11, 2016 | 07:07 AM
awq134's Avatar
awq134
I guess I should have asked if your tuck is 4x4 first. the reason being is that when you say that the chatter goes away when you let off the gas it sounds a lot like an IWE (integrated wheel end) issue. Mine was getting a partial vacuum when I was on the throttle and it would try to engage the iwe's and as soon as I let off, the noice would go away.
mbrandeskc
Jul 2, 2013 12:58 PM
Jack01
Sep 30, 2003 01:26 PM
