95 F150 turn over no start
Old 04-03-2016, 02:35 PM
hapkidoman's Avatar
hapkidoman
hapkidoman is offline
I have a 1995 F150 5.8 . It has been having starting issues. It will turn over but not start. I can hear the fuel pump engage. I changed the ignition coil and that worked for a day or two. Then I changed the ignition switch and it has been fine for the last 4 days. Now it won't start again. I need some suggestions on how to diag it instead of just replacing part. Any help would be appreciated.
Old 04-03-2016, 06:22 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
pull the codes .
(yes, there can still be codes even if the 'check engine light' is not on).
Old 04-03-2016, 07:29 PM
hapkidoman's Avatar
hapkidoman
I need to find a way to do that. It is too old for any OBD II scanners
Old 04-03-2016, 07:52 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
You just need a paperclip and a piece of paper to pull the codes on these trucks.
Old 04-03-2016, 09:19 PM
Remmons's Avatar
Remmons
Remmons is offline
I had 95 it would crank all day but no start it was a plugged fuel filter.
Old 04-04-2016, 06:57 AM
subford's Avatar
subford
subford is offline
When it does not start pull the SPOUT shorting bar out and see if it will start then.
Let us know what happens.
Old 04-05-2016, 06:18 PM
hapkidoman's Avatar
hapkidoman
I used a spark tester today. I believe that it is the distributor i had spark to the distributor but not coming from it.
BigEazy619
06-07-2019 08:47 AM
Ford Trucker 2008
1997 - 2003 F150
09-11-2009 07:15 PM
maritnry
1983 - 2012 Ranger & B-Series
12-27-2004 03:10 AM
mavman
1997 - 2003 F150
07-15-2002 06:55 PM
Quick Reply: 95 F150 turn over no start
