I have a 6.9 yesterday driveing around motor runs good then lase night we went to a sell run good I filled up with fuel was comeing home it had a small miss in motor. I started it these morning I could tell it had a miss started ezey. Went to farm turn it off went to leave and it would start. Pulled it about 10 feet it started up it was runing and smoke like crazy I turns it off tryed to restart and it wouldt start. Any help I wold like
welcome to FTE.
first thing i would do is pull the fuel filter and pour it into a clear container to see what is in there. it sounds like you got a load of water.
or gas instead of diesel.
if the filter was indeed full of diesel and had no water or gas in it, fill the filter with good diesel or automatic trans fluid, re install, and see it it will start.
