need help really bad
Old Mar 30, 2016 | 09:36 PM
johnhoward32's Avatar
johnhoward32
Red face need help really bad
hey guys i turned my 250$ f350 one ton for wheel drive 7.3 turbo powerstroke into a mud truck. heres where im having problems.
i got it home washed it a year ago let it sit until i moved. well its been a year now. i went start it a few months back and the ecm had some smoke come out of her....... i am running the ts6 performance chip in it as well.. i put a new crank shaft position sensor in it, a new ipr, and new orphice tube kit. im not getting any smoke out of the short exhaust i have on it which comes from the turbo through the hood stack....... but will pop off with either (i know its terrible to use ether)...
any help would be awesome... dont want to take it to ford and spend an arm and a leg
Old Mar 30, 2016 | 09:39 PM
MI02SVT's Avatar
MI02SVT
You had smoke come out of the pcm and you haven't thought to check there first does the wait to start light come on try unplugging your chip see if anything changes
Old Mar 30, 2016 | 09:41 PM
johnhoward32
i replaced it with a good used one from work with a stock chip and still nothing..
i habe no wait to start light also
Old Mar 30, 2016 | 09:55 PM
MI02SVT's Avatar
MI02SVT
Have you checked all the fuses
What's a stock chip
Old Mar 30, 2016 | 11:55 PM
oldbird1965's Avatar
oldbird1965
If your going to spray drugs then disable the GP relay.
Old Mar 31, 2016 | 12:36 PM
madpogue's Avatar
madpogue
Using starting fluid when you have no WTS light is a complete waste of time (and, as hinted above, a good way to blow up your intake or worse). Sure, it'll fire, BRIEFLY, on the starting fluid, but no WTS generally means no PCM power, so it'll just burn off that starting fluid and go back to a crank-no-start.
FIRST thing to do is restore PCM power. There is no "stock chip". So install a known good PCM with NO chip/tuner/programmer and attempt to start. If still no WTS, check fuse #22. If blown, DON'T replace it. Disconnect the fuel bowl heater, THEN replace.
You obviously didn't replace the crank position sensor; there isn't one. If you replaced the CAM position sensor, what brand did you buy?
glovemeister
Mar 19, 2018 05:27 PM
1a2a3a
28
Jan 28, 2016 03:46 PM
sand1
Feb 9, 2013 08:22 PM
bigred02sd
Oct 10, 2008 08:02 PM
jimwilsonmasonry
Jul 19, 2008 09:07 PM
