We Own Work: My 2017 Super Duty Experience
#196
Current 6.7's has 1500CCA available - but of course the starter and glow plugs don't draw all of that. Even so, 150A would "equal" the supply from the stock batteries. Many homes have a 200A service.
In reality, the compression of a 6.7L is not that high - 16:1. I'm guessing the starter motor on a cold day might draw 500A. Still, you'd need a circuit in your house rated for that kind of draw.
On the other hand, the owner's manual states the fuse for the starter motor is rated for 40A.
#197
Our main truck terminal, as well as many service trucks, used to have a "Goodall Startall" which was a gasoline driven generator for starting trucks with low or dead batteries. Ours was medium size and produced around 1000 amps at 24 volts. The most difficult part was the transfer of the current into the batteries. It would often blow the terminal right off the top of the batteries, thus destroying them. Sometimes the batteries would be partially or completely frozen and then the battery would self destruct sending shards of battery case and acid in all directions. Large amperage needs to be respected. As for a 120 volt starter the amperage would be significantly reduced and would probably be a viable solution if the vehicle had consistent difficulty in starting. But, the newest Powerstrokes are better than ever at low temperature cranking and starting. Ford has a whole test and engineering unit assigned to overcoming the cold weather difficulties as witnessed by one of the promotional videos available elsewhere on the interweb. Keep in mind a wholly separate starting system would add substantial weight and compete for valuable space under the hood. I would vote to enjoy the increased engineering of the existing systems and the only change I would see beneficial is the ability to bring temporary power into the system. I have found it extremely difficult to jump start a 7.3, especially with only one vehicle. Even with two vehicles connected the weakest link is the clamps of the jumper cables which due to the teeth needed to grip the battery terminal only allow some of the current to pass. Allowing an extended time connected to the running donor vehicle and allowing the truck batteries to charge has been the only way I have been able to get the truck started when its' own system has failed. And if one of the batteries has developed a dead cell and will not take a charge, forget about it.
#198
well the the current super dutys do sit level , unless it has a the optional hd rear springs or camper /towing pkg. And If they have the snow plow prep, then they actually sit higher in the front. I was just wondering if the new sd is the same way. I actually like them leveled. I drive more empty than i do towing, and when i do tow, i can put up with it sagging a little, but i understand that some folks tow everyday and it would be different for them.
#199
#200
#201
No one really knows yet. Numbers expected out sometime in July. Expectations range from just beating out Ram at 925 to making a huge statement at 500/1000. They are all just guesses at this point though...
#202
My lifetime fuel economy on my 2016 6.7L (10k miles on it) is 16.0 mpg. A lot of that is unloaded commuting, but some of it is towing and city.
The 6.7L will easily achieve 20mpg or better on the highway just commuting. But a tank average with a regen and some towing or hauling will be substantially less.
Ford may try to improve mpg on this engine update to help with CAFE standards rather than go for the knockout power punch.
#203
That was true from 11-14 for the 250's but starting sometime in 2015, many of the 250's started coming with the same 4" spacer block as the SRW 350's in the back giving them the same rake unloaded. I believe the 2017's will all have a 3.5-4" block if the truck is 4wd. Even the DRW's.
#204
Troverman....I have to dis-agree on this one. The 6.7 has NEVER easily achieved 20mpg or better on the highway. Maybe in RARE cases...but overall the 6.7 barely gets 18 on a "mellow" highway drive...and that is doing probably 55-60....anywhere over 60 and the 6.7 will NEVER see 20 mpg...at least it hasn't for mine or the 10 friends of mine who all have 250s and 350s. I see people throw out that elusive "20" with these trucks...but it's rare....not easily achieved. That being said, lets cross our fingers and see what the future brings with the 2017 and beyond...but I'm not going to jump in the air just yet. You said your lifetime average is 16...now that's right in the ballpark of what this truck delivers.
#205
#206
#208
You can believe it or not. Doesn't matter much to me. Tons of guys have bought new 250's with 4" blocks. It was discussed ad nauseum in the 6.7 section a couple years back complete with owner experiences and pictures. Some surmised it was the camper package that added the 4" blocks to a 250. Others said it was the plow pkg. Some said either/or. Some said they had neither but had 4" so IDK. All I do know is I don't believe these folks were lying about how their trucks were built.
The pics you posted both look just like my truck which is a 350 with 4" blocks depending on the angle of the picture. Perhaps you eye isn't as finely tuned as you think...
#209
I guess I'll have to go back and look at the discussion and pics...because I'm just not buying it....Yet....lol. I easily just found 30 or 40 pics of 2015 and 2016 F250s searching Google etc.....and they were ALL 2 inch blocks in the rear. Maybe those guys did a swap or something special at the dealer...but I'm just not seeing ANY 4inch blocks on F250s.
