throttle body spacers
Old Aug 12, 2003 | 06:28 PM
makaveli4eternty's Avatar
makaveli4eternty
Has anyone tried these in their rig? i have heard mised reviews of them and i was wondering overall how would yall rate them on performance gains, ease of installation, and overall how much better will it make the engine run?
Old Aug 23, 2003 | 10:36 AM
true4.2's Avatar
true4.2
If you get any performance gains, it won't be too much. From what I've heard, a spacer can make maybe 5...6 hps? I really don't know. If you are planning on decking your ride out with tons of parts, every little thing helps. But if you are just goin to get a spacer, you won't notice a thing.
Old Aug 25, 2003 | 01:16 AM
silvapain's Avatar
silvapain
are you talking about a phenolic spacer? I would think it would be better just to put a spacer between the upper and lower intake maifold. that would keep the upper intake, throttle bady, and MAF sensor from getting any transmitted heat.
Old Aug 25, 2003 | 05:05 PM
jdb1937's Avatar
jdb1937
i agree totally with true4.2. may not even do anything at all. I put one on my 1998 Jeep Wrangler 2.5 (not a Ranger) because i wanted to lift the intake up a little to clear my after market open element air filter. The spacer was just enough that it worked perfect for the clearance i needed, as for improving perf on a 2.5 4 cyl Jeep- no. But they could make more difference with, say, a V-8 or 4.0 V-6. If you decide to put one on- let us know how it works. But i wouldnt expect a new engine after you do it! J.D., KCK
Old Aug 25, 2003 | 06:56 PM
DW2455's Avatar
DW2455
I cant tell you about the throtle body spacers, but all the dyno reports i've say a phenolic spacer between the upper and lower intke will increase your tork by a notable margine, simply because you lenghtened the intake runners. im not sya this from experience, just from the reports i've read. DW
Old Aug 27, 2003 | 03:18 PM
silvapain's Avatar
silvapain
phenolic spacers are not so much for the added height, but for the heat insulating purposes. A G10 phenolic plastic spacer will drastically cut down transmitted heat into the upper intake manifold and MAF, keeping the intake air much cooler and thus denser.
Old Aug 27, 2003 | 03:23 PM
DW2455's Avatar
DW2455
yes heat insulating is a added benifit but when you extend the runner lenght, whether its with a alum. or phen. spacer you increase low end tork, thats why the truck intakes are taller than there passenger car counter parts. DW
Old Aug 27, 2003 | 10:47 PM
silvapain's Avatar
silvapain
true, but you loose hp in the high rpm's. the reflective value will be too long. The length of the runners depends greatly on applications: for example with my taurus I want the runners tuned for about 2500 rpm's. I'm sure you truck owners would want it lower, for towing especially.
Old Aug 28, 2003 | 08:52 AM
DW2455's Avatar
DW2455
the question was in regard to trucks, HP dosent move heavy trucks. tork does, and were talkin street motors here, looseing HP in the upper rpms is just fine considering on the street you'll be in the 1500-3500 rpm range 85% of the time. thnx DW
Old Aug 29, 2003 | 12:55 AM
Peter94's Avatar
Peter94
I was looking into getting a throttle body spacer but i couldnt find one for my 94 4x4 4.0L ranger. if you guys know who makes one or where i can find one that would be great
Old Sep 2, 2003 | 07:56 AM
silvapain's Avatar
silvapain
if you want low end torque, then i suggest getting a prted, polished, and tuned length intake. Adding a phenolic spacer to do that is just trying to guess at a length.
Old Sep 2, 2003 | 08:17 AM
DW2455's Avatar
DW2455
Oh well i gues all these well respected engine builders and the dyno reports were just WRONG? DW
Old Sep 14, 2003 | 12:21 PM
true4.2's Avatar
true4.2
To Peter94:
I haven't checked these sites for ya yet, but they could be of some help...
www.motorhaven.com
www.seffects.com
http://www.seffects.com/search/auto_...dies&type_id=2
try the above link for a helix power spacer for about 90 bucks.
http://www.seffects.com/search/auto_...tems&type_id=2
Also, if are interested in some headers for some horse power, click the link. Sorry, I had some time on my hands.
Old Sep 16, 2003 | 04:02 PM
Peter94's Avatar
Peter94
Hey thanks alot true4.2, just what i was looking for. I might get around to ordering one in the future here, i'll let you know how it works
Old Sep 28, 2003 | 09:39 AM
true4.2's Avatar
true4.2
Cool, no problem man. Good luck with tha mods!
