ANOTHER 7.3 NO START, HPOP RELATED..NEED YOUR IDEAS
I don't think so assuming you are reading PSI with a scanner. You are reading what the PCM is requesting, trying to ramp up the pressure to a starting value. Only way to tell real pressure is either hook up a gauge or measure the ICP actual voltage. Once started then ICP reported pressure via a scanner will be correct, if not the PCM will throw a code.
Measure the ICP voltage, either by scanner or meter. That will eliminate a lot of guessing.
Its the negative side of the plug that provides feedback to the ECU via square wave pulse width modulation... IPR is the control valve for the oil is all...
I will let you know... Thanks for your help. I was simply trying to think through this as much as possible before taking it all apart.
Like I mentioned I forgot to record fuel pulse width, based upon these number I should have something correct? .3-.45 ms approx? If i get nothing i'm guessing a have an electrical problem vs mechanical...
Right on man! thankyou! I'm going to take a bit of a lunch from the real job and go home and see what I get there... I'm making a wild guess right now we have 0.
Well I will take a look at both swap the relay for the blower motor, and toss a new CPS in for the heck of it, it was plugged in. I did check that. I am registering rpm though..
Got home, fresh batteries, logged again, this time we had +3000 psi easily for quite some time, ICP voltage was 3-4 volts and remained constant around 3.2.. I wasn't paying attention to DC all too closely but I'll post the log. I cranked for 4 burst at 20 seconds... same thing... nothing
NO FIRE!!!! 0 MS FPW still.
Ironically the chip shows up today too.... so ran up to the house and grabbed it thinking it was easier than doing the CPS next. I swapped relays and plugged the chip in. Right as oil pressure builds she fires right off and idles nice and smooth... I almost crapped my pats. Turned the truck off after 15 seconds or so of running, and did a jig with the dogs super happy.
Going to eat dinner and go back to it. So freaking happy. I thought we had something bigger going on. The entire time my buddy kept saying chip and i affirmed it wasn't possible... will verify when I go swap relays again and see if it starts. If it doesn't I will swap them back and test again...If that is the case.... and it was the chip, I need an explanation... I have never seen a truck run without a chip, and only with one.... It has always been the opposite. I am starting to wonder if the lock out security deal had to do with the PATS system when it was disconnected... it did not reset till the chip was back in? I don't think thats possible either unless they truly pulled the security key off the PCM....somehow.
That all being said I have a hard time believing it was due to lack of oil. I think we had a solid 10 minutes worth of cranking on it over 3 days. The irony that it fired right as it built pressure baffles me, idled fine till I turned it off.
I will report back!
#28
Not the relays...it was the chip. I swapped them and it was the same thing. Fired right up within 3 seconds of low pressure oil needle moving.... So I'm at an electrical loss. Unless its a cali model specific deal to have the PATS code on the chip, then I still don't believe it....
I will be calling gearhead to bounce a few questions off them.
#29
