Rust proofing??????
Old Mar 27, 2016 | 07:54 PM
lumpy76's Avatar
lumpy76
Rust proofing??????
Hi all. Got the call yesterday with VIN # and build date starting on 4-18 for the new truck. Really pumped. First new car ever.
Live in the terrible rust belt. Does anyone offer rust proofing that works? Have not asked the dealer yet but would like some real world experience. thanks.
Old Mar 27, 2016 | 08:38 PM
Tom's Avatar
Tom
I've been using Fluid Film for the last few years with great success. It's not a permanent coating, you just spray the underside liberally in the fall, and it does a good job lasting all winter long. Because it's not permanent you don't have to worry about overspray, it can come off with soap and water.
Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
Check out this thread:
https://www.ford-trucks.com/forums/1...s-applied.html
Old Mar 28, 2016 | 03:02 PM
lumpy76's Avatar
lumpy76
Thanks Tom. Sounds like a plan.
Old Mar 28, 2016 | 09:14 PM
fordman19762003's Avatar
fordman19762003
I second the Fluid Film
Old Mar 29, 2016 | 09:30 AM
shatfieldj's Avatar
shatfieldj
Just ordered one yesterday. How long did it take to get your vin?
Old Mar 29, 2016 | 03:25 PM
xr7gt390's Avatar
xr7gt390
I'm not a fan of rust proofing. If you decide to get it, make sure it doesn't void your manufacturer warranty.
I know people who think Fluid Film is the best and some others that like LPS 3. At least with these products your Ford Corrosion Warranty is still good.
Old Mar 29, 2016 | 05:03 PM
lumpy76's Avatar
lumpy76
Fast! Ordered around 5:00pm on the 23rd. Called with VIN on the morning of the 26th.
Old Mar 29, 2016 | 05:04 PM
lumpy76's Avatar
lumpy76
Thanks for bringing that up, never crossed my mind. I will just go with the FF. Ordered some from supplier at work already.
Old Mar 29, 2016 | 05:42 PM
Tom's Avatar
Tom
It's not that I think Fluid Film is necessarily the best, but it's cheap and effective. I like the fact that it's not permanent and is unlikely to cause issues. I don't have to worry about overspray because it can be washed off easily.
If someone has a better idea I'm all ears, but so far Fluid Film has been tough to beat. I paid $40 for a gallon of the stuff two years ago, and I apply it with an air gun.
Old Mar 29, 2016 | 08:50 PM
shatfieldj's Avatar
shatfieldj
Great. Thanks.
Old Mar 30, 2016 | 06:11 PM
dmags's Avatar
dmags
Aren't these trucks made of old bud cans?
I mean Military grade aluminum:-
Old Mar 30, 2016 | 06:31 PM
sbryan's Avatar
sbryan
I'll third the Fluid Film. It is a lanolin based product that needs to be applied every year but because it is more like an oil than a tar or other hard coating it displaces water and doesn't trap moisture. It's cheap, been effective for me on 8-10 year old vehicles in salt drenched VT. It does stink for the first few hours after application but not in a horrible way. You also don't need any special protective equipment to use it and it is biodegradable so if it drips on the lawn or in your garage just hose it off.
Old Mar 30, 2016 | 10:41 PM
429SCJ's Avatar
429SCJ
Another vote for Fluid Film.Although it works great,it's not biodegradable.
Old Mar 31, 2016 | 05:58 AM
sbryan's Avatar
sbryan
You are correct - not biodegradable - I should have said non-toxic and not apparently harmful to the environment. Thanks for the clarification - sloppy language on my part.
Old Mar 31, 2016 | 08:37 AM
429SCJ's Avatar
429SCJ
No bigge.By the way,nice rig in your sig and thank you for your service.
Mark
