What's the correct name for the vacuum switch that the brake booster hose connects to?? I need one that just has the outlet for the brake booster/mine has several unused ports. Part#??
Are you talking the black thing on mine just to the left of the master?
If so that is a check valve for the booster. They come with different sizes to fit different boosters.
Should be able to get one from the local parts store help section.
If that is not it post up a picture of what you have and explain what it is you are trying to do.
Dave ----
Numbers, when he said "booster" I thought he was looking for the check valve.
When I said different sizes I meant for any car or truck if he hit the parts stores so he would not just grab and run.
It turns out he is looking for a vac tree that screws into the intake manifold that only has 1 or 2 ports and not the 5 or 6 he has now.
I would pull that one out and hit one of the old parts stores or NAPA and see what they have.
Dave ----
