Sponsored by: Real Truck
ESOF Problems
Old Mar 25, 2016 | 04:16 AM
Fordrc15's Avatar
Fordrc15
ESOF Problems
My son has a 2003 Super Duty with auto locks, but the front wheels won't lock even when turn to locked position. Also when it's in two wheel drive the front drive shaft and axles still spin, are the hubs locked up or is it in the transfer case?
Old Mar 25, 2016 | 04:45 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE Fordc15.
I moved your post to a new thread, so it would not be buried at the end of a 5 year old thread.
Try this. With the hubs in AUTO and the switch in 2WD, reach around behind a front tire and try to spin the U-joint. It should spin free, although you may feel some resistance.
Old Mar 25, 2016 | 10:06 AM
senix's Avatar
senix
Also sounds to me like the hubs may need servicing.
Old Mar 26, 2016 | 08:19 PM
Fordrc15's Avatar
Fordrc15
Thanks Redford and Senix for your repose, I'll give that a try. I'm pretty sure the hubs need attention sense I had to use pliers to turn them.
Old Mar 26, 2016 | 08:31 PM
senix's Avatar
senix
check this link out for some help:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Mar 28, 2016 | 05:57 PM
Fordrc15's Avatar
Fordrc15
Hi Redford,
I try turning the drive shaft like you said, but no luck it looks like its stuck in 4x4. If it's in constant 4x4 will that cause the hubs to strip by running on dry pavement? Is there anyway to disengage the transfer case manually?
Old Mar 28, 2016 | 10:11 PM
jetjockey99's Avatar
jetjockey99
If the front hubs are locked, either failing to release or in the locked position the drive shaft will not spin, even if transfer case is in 2wd. You can jack up 1 or both front wheels and see if you can turn shaft, if it turns then transfer case is in 2wd and it is okay to drive on hard pavement, if it still won't turn then it is in 4X4 and you should not drive on hard surface roads. You can shift from 4X4 to 2wd by removing the shift motor on the t-case and turning the exposed shaft.
Old Mar 29, 2016 | 05:08 AM
redford's Avatar
redford
jetjockey99 is correct. It sounds like you need to rebuild/repair/replace your hubs.
Old Mar 29, 2016 | 10:45 AM
wizkid00104's Avatar
wizkid00104
Here are a few more:
Additional Hub Service write-up: 2004 F250 ESOF Hub Service
How to remove the hub ****:
https://www.ford-trucks.com/forums/1...l#post14810028
This is for the vacuum system that actuates the hubs: https://www.ford-trucks.com/forums/1...l#post15890712
Old Mar 29, 2016 | 04:55 PM
RedNNBlue's Avatar
RedNNBlue
I had similar issues a few years back on mine. Had to use pliers or channel locks to turn the hub because they wouldn't lock automatically.
I ordered Warn premium manual hubs. Install took about 10 minutes for both sides and I know with absolute certainty when they're locked or not. They have been great for several years now with no problems. I highly recommend switching out the stock hubs for Warn.
Old Mar 29, 2016 | 08:15 PM
Fordrc15's Avatar
Fordrc15
Thanks for all the suggestions, I'll probably just replace the hubs.
whodat_ford
Jan 22, 2018 06:07 PM
ford67boy
May 2, 2012 10:30 PM
RA81222
1978 - 1996 Big Bronco
Apr 13, 2006 01:42 PM
RA81222
Feb 24, 2004 02:05 PM
brmann
Aug 14, 2001 08:16 AM
