Air horn to the air brake system
#31
If you noticed in the above diagram I attached and read the entire thread I do have a shop manual and I am consulting it yet again there are no valves between the different reservoirs in the air system that being said I fail to see how this compromises the brake system. I apologize for having to college education and using what I learned at a university in conjunction with the skills that I possess I simply was looking for information in the future I will not contact you or ask for your input and I would ask you to do the same. Good day and happy Easter
#32
#33
The primary and secondary tanks both have check valves between them and the supply tank to prevent back flow should the supply tank lose air pressure for any reason.
There's a double check valve between the primary and secondary tanks to insure one tank has air pressure to operate the brakes should the other tank lose pressure.
These check valves serve as a back up and safety system that is man dated for all trucks and buses equipped with air brakes.
Just so everyone knows there's a safety check valve in the supply tank that is designed to relieve pressure above 150-175 psi to prevent the air lines or any other part of the air system from blowing up.
In over 30 years of driving and working on big trucks I've never see anyone tap into the air governor supply line to operate another device, not saying it's a bad thing, just never seen it done before. I can see where it would cause the compressor to short cycle while the horns are being blown, only down side I can see is possibly increasing the wear rate of the unloader valve in the compressor.
#34
#38
#40
Marine Corps "Cluster "Hump"" !
usmcpat said: "Well completely disagree with y'all! I'm going to fire it up and keep an eye on pressure and see how it goes. From what I remember from physics class the pressure drop shouldn't be an issue. Worst case scenario the compressor will start building more pressure in the system if there's a loss of pressure on the governor. If any thing it will allow the system to recover faster from the drop in pressure if I hang on it."
My recollection is that the term "cluster f---" comes from the US Army. However, I'm becoming convinced that it may apply more generally to other branches of the military.
#41
roKWiz: I like your air supply tie-in. Do ya spoz that's why there's an air manifold with unused ports ?
Geoff
#45
