Where is my PCM????
Where is my PCM????
Ok, was going to install my TS chip and looked under my dash by the e-brake and its not there.... there is a wire harness that connects where it is but where did they put it??? Any thoughts.
I tired for follow the wires but they go up in the dash and I loose site of them Anything that would give me an idea or a clue of what to look for that might point me in the right direction?
WTF... nothing is easy.......
on
1 Post
It is behind the park brake assembly. You have to remove the park brake assembly. The PCM is removed from under the hood through the firewall. You have to take the screws and bolts out of the rear half of the driver side inner fender and drop it down to have enough room to slide the PCM out.
Your pic is just showing the harnesses going through the firewall. Did you unbolt the parking brake pedal/release assembly and push it toward the right side of the truck, and look BEHIND the assembly? (You don't have to disconnect the cable and remove it, just unbolt it and move it aside.)
FarmingF250
1999 to 2016 Super Duty
29
03-24-2021 03:02 PM
exbxtoy
09-21-2016 06:05 PM
powerstroker100
07-10-2014 01:11 PM
