1978 - 1996 Big Bronco
Tranny Overflow???
Old Aug 12, 2003 | 12:51 AM
NiteMan69's Avatar
NiteMan69
Tranny Overflow???
Just trying to see if anyone else has had this problem...
I have an E4OD Tranny on a 302. When I am on the highway for about a minimum of about 10-15 minutes and then pull off an exit, the transmission fluid comes up the fill tube. It has even done this while on the highway and the fluid sprays out the back after it leaks down the tube and onto the underside of the truck. I have a new converter in the tranny as i just did an engine swap. I know there is a purge valve on the top side of the tranny but that is always dry after it "overflows" out the dipstick tube.
Any help would be greatly appreciated.
Thanks, Glen
91 Nite Edition
Old Aug 13, 2003 | 09:05 PM
bigric's Avatar
bigric
Tranny Overflow???
This happened to my '92 a few years ago. Changing the filter solved the problem.
