No need for LEDs
Old Mar 14, 2016 | 01:49 PM
HoustonDave's Avatar
HoustonDave
No need for LEDs
Half the dash lights were out, so after fixing a couple of other issues I pulled the cluster out - polished up the light contacts with some 1000 grit, greased 'em, tested the bulbs and reassembled - I also threw some flourescent orange on the needles, polished the clear cover and pulled those stupid blue filter caps off. Was not able to reach the gear indicator bulb in the time I had so you can see the contrast.
Expense - absolutely zero, and I can actually see my gauges now.
Old Mar 14, 2016 | 02:12 PM
jbehuniak's Avatar
jbehuniak
looks good.
Old Mar 14, 2016 | 02:13 PM
WhichDoc's Avatar
WhichDoc
NICE!!! wish i did this before spending 50 bucks....
Old Mar 14, 2016 | 02:16 PM
co425's Avatar
co425
Yep, those damn blue filters are 90 percent of the issue with gauge lights. The main benefit of the LEDs though is reduced load on the electrical system.
Old Mar 14, 2016 | 02:19 PM
WhichDoc's Avatar
WhichDoc
my lights still flicker and pulse with the engine running even after I swapped in the LEDs. Hopefully that'll change with the HD harness...HOUSTONDAVE that really looks good, plus saving cash is a good thing!!!
Old Mar 14, 2016 | 02:23 PM
HoustonDave
I already put the headlights and driving lights on relays - ran 10 gauge wire from the battery, stripped it, soldered it solidly to all the left-side posts of a small fuseblock as a bus bar, then on the right side of the fuses have separate relays for low beams, high beams, and driving lights. Would think the remaining aging wire should hopefully handle it... God knows I have cleaned up seemingly every ground in Texas already.
Old Mar 14, 2016 | 02:24 PM
co425's Avatar
co425
Did you clean and grease your grounds throughout your truck. Which lights flicker and pulse?
Old Mar 14, 2016 | 02:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Nice, very nice and thanks for the blue filter tip.
Old Mar 14, 2016 | 07:45 PM
gijazbo's Avatar
gijazbo
is it irritating when driving at night? For example newer cars dim the gauges once the headlights come on to facilitate seeing the road more clearly. Just wondering
Old Mar 14, 2016 | 09:17 PM
54Hydro's Avatar
54Hydro
The alternator can cause that as well if one or more of the diodes quits operating properly.
Old Mar 15, 2016 | 03:23 AM
burnthelight88's Avatar
burnthelight88
Nice to see someone else puts a vac gauge on their ride... yeah I'm also wondering if that would be too bright at night, if you say it isn't I think i'm going to do it too.
Old Mar 15, 2016 | 06:18 AM
stronger66ratfink's Avatar
stronger66ratfink
wish I had someone with me that knew how to get it out farther than I did when I changed the bezel and tried to fix a couple of lights that are out in mine?
couldn't get the speedo cable out.
I was able to reach them, put new in but they still didn't work, thinking maybe that might of been why the original owner had a replacement gage with the truck when I got it, maybe because the brass contact pad is bad?
Old Mar 15, 2016 | 07:19 AM
Steven@nd's Avatar
Steven@nd
If the lights are too bright, turn the headlight switch to dim them...
Old Mar 15, 2016 | 11:27 AM
HoustonDave
Yes, the dimming was turned all the way up for the picture - they dim about 50% which is fine. Given that this is mainly driven in suburbs which tend to have a lot of ambient light from streetlights etc, it works for me.
Stronger66- Removing the cluster is not terribly difficult - usually the worst parts are the speedo cable and the big master plug in back of the cluster which locks into place and can be a bit of a bugger to unplug. I did not even take the circuit sheet off - just carefully polished the contacts with some fine wet/dry in place. Worst case, you could check a wiring diagram to determine which wire is the 12+ for the dash lights at the plug, and jumper to a 12V source like the positive post on your battery - then touch a grounded test light to each side of the bulb socket contacts. This is not modern high-tech stuff, the traces are about an 1/8" across! As long as your test light lights up on one side or the other of the socket contacts on the printer circuit overlay, you're golden. Also make sure that the contacts on the sockets themselves are shiny and bent up enough to contact the circuit contacts - I found two bulbs which started working again once I bent their contacts out a bit. Absolute worst case, that circuit overlay sheet is I believe about $65 or so from various sources like LMC.
Old Mar 15, 2016 | 04:03 PM
somethingclever's Avatar
somethingclever
nice job OP~!
