Lowering Advice
Old Mar 14, 2016 | 02:18 AM
F100Jay's Avatar
F100Jay
Lowering Advice
Hi all, Im after some direct advice.
I want to lower my 53' F100. Its currently stock suspension wise.
I want to remove a few leafs from the rear springs to soften the ride, and i keep seeing mention of being able to re-drill the leaf mounts at th top of the frame and drop a few inches there. Can i get more details on this method? Do you re-drill both mounts back and front of the leaf springs? I have seen mention of swapping the mounts side to side? is this because of the flat part that curls under the frame?
Also i've seen references to releasing the energy from the spring pack in the correct manner. But have yet to see this procedure outlined anywhere. Could someone please elaborate?
Will be buying Posie springs for the front for the meantime. In the process of refurbishing front and rear Jag subframes but time is running out for this season so they will become projects for next winter.
Cheers,
Jay
Old Apr 19, 2016 | 11:40 PM
Jules The Great's Avatar
Jules The Great
On releasing energy from the spring pack I can only guess that it is for safety? Just put a C clamp on there before you undo the center bolt in case the springs are pushing hard on the pin?
If you are putting in Jag suspension why mess with the existing and not just wait to install the "new" stuff?
Outlaw56
Mar 18, 2015 09:45 AM
The_SnowMan710
Offroad & 4x4
Aug 6, 2008 12:11 AM
biglee
1947 and Older Ford Trucks
15
Feb 28, 2006 11:05 AM
ZZMAXX25
16
Jul 12, 2005 04:31 PM
samwe
Jun 4, 2004 05:21 PM
