shifter linkage bushing
Old Mar 12, 2016 | 10:40 PM
1browski's Avatar
1browski
In the picture below, my shifter linkage rod is missing what I assume is a bushing connecting it to the transmission. It is a c6 tranny. I found an old thread that showed some part numbers, some obsolete, and some not. Will the part #EOSZ-7341-A work on my 1970 f250.
Old Mar 13, 2016 | 11:19 PM
1browski's Avatar
1browski
Exclamation
just bumping this up. worst case, I will buy it and try it.
Old Mar 14, 2016 | 03:26 AM
GaryKip's Avatar
GaryKip
I can't help, but someone on here will give you some parts info. Just hang on!
Old Mar 14, 2016 | 10:13 AM
Uni Moe's Avatar
Uni Moe
This?
Auto Trans Shift Linkage Bushing ATP fo 300 | eBay
Old Mar 14, 2016 | 04:19 PM
1browski's Avatar
1browski
something like that. when i put the truck on that it says it doesnt fit the truck
Old Mar 16, 2016 | 09:31 PM
JEFFFAFA's Avatar
JEFFFAFA
Transmission gear shift selector arm insulator:
69/72 F100/350 bumps, 360/390,C6, on trans lever, originally brown in color, part number C80Z7341A.
C80Z7341A r/b D5AZ7341C.
D5AZ7341C r/b E0SZ7341A.
E0SZ7341A r/b E0SZ7341B. Which from memory I think is blue.
I believe E0SZ7341B is still replaced by Ford. I would contact your local Ford dealer. Go original Ford. Not aftermarket unless you have to. Aftermarket ones will be made out of a different material and prolly harder to install. Once you get it install it in the lever 1st. Then poke the rod through it.
Old Mar 18, 2016 | 01:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1browski
Will the part # EOSZ-7341-A work on my 1970 f250.
Replaced...
EOSZ-7341-B (replaced C8OZ-7341-A; C9TZ-7341-A; D5AZ-7341-B & C; EOSZ-7341-A) .. A/T Selector Arm Nylon Bushing / Available from Ford.
Old Mar 18, 2016 | 11:10 PM
1browski's Avatar
1browski
thanks for the help. havent been on here for days been working too much this week on nights.
Old Mar 19, 2016 | 01:47 AM
bert cook's Avatar
bert cook
i went down to the hardware store and bought an assortment of those rubber grommets that you use for putting wires through through fire wall found yhe right size works perfect
Old Mar 19, 2016 | 03:06 PM
1browski's Avatar
1browski
Im still going to get the correct part but I made one up today to see if it would immediately fix my problem. It did. Now I do not have to lift up on my gear shifter to start the engine. It also firmly goes into park and stays there.
Old Mar 21, 2016 | 12:16 AM
GaryKip's Avatar
GaryKip
The grommet will last until it's pouring rain, it's late at night on a busy highway, and your date has to go home right now (so she won't be late for her new job), and your flashlight batteries are dead.- you know, it's the Murphy Law thing, all over again.
Old Mar 21, 2016 | 12:31 AM
1browski's Avatar
1browski
I have one ordered now. I dont like how it is for long term but its better than it was until the new one arrives. after pulling it apart, not sure how much longer it would have lasted.
Old Mar 26, 2016 | 03:54 PM
1browski's Avatar
1browski
part came in and installed. perfect fit. eosz7341b
Old Aug 28, 2016 | 07:54 PM
dkj313's Avatar
dkj313
I have a 1970- 3 on tree how do you remove the shifter bushings on the manual transitions puzzled
Old Aug 6, 2018 | 04:38 PM
mcintosh77's Avatar
mcintosh77
How to reinstall
How did you get the bushing back in? I've tried with a c-clamp but it just deforms the bushing. I have an OEM replacement on order.
