Window Mount Cellular Antenna
Old Aug 11, 2003 | 09:13 PM
Pastmaster's Avatar
Pastmaster
I need to remove my cellular antanna from my F150. Is there a process for doing this? I removed the little cap on the inside part, and apparantly there is a bolt that holds it on?
Old Aug 12, 2003 | 06:59 AM
brown 4x4's Avatar
brown 4x4
Does it just stick on? When I removed mine, I just parked it in the sun and slowly peeled it off. Then I used a razor blade to remove the residue. The bolt isn't for the antenna mast?
Old Aug 12, 2003 | 08:44 PM
Pastmaster's Avatar
Pastmaster
The bolt doesn't go through the windshield, so I don't know what the bolt is used for?
I've had it there for around 9 years, and it still works, so I want to keep it and put it in a new truck. I just can't figure out how it's attached.
I guess I should call Alltel!
Old Aug 12, 2003 | 11:00 PM
TexBand's Avatar
TexBand
It's attached with super glue, like the rearview mirror. It uses some kind of induction to get the signal through the glass. (I'm going on what my old one had, I'm not an expert.)
You should be able to get it off by using a razor blade between each side of the antenna mount and the glass. Just don't pry, or the razor blade shatters and the sharp parts hurt.
Chuck
Old Aug 12, 2003 | 11:34 PM
aprice's Avatar
aprice
try a blowdryer, heating it up will help removing it easier and might leave less residue,. i dunno, i had a similar anttena on my truck and the came off pretty easy with a razor and a blow dryer, be carefull not to cut the window though
