Recharging an ac system question
Old Mar 11, 2016 | 05:40 PM
Christopher Layton's Avatar
Christopher Layton
In my 1990 F350 truck the AC isn't currently working because the schrader valve on the low side leaked out all the refrigerant a couple of years ago.
Does anyone know how many 12 oz cans these trucks take? My truck has the 7.5L engine.
Would I need to change out the receiver dryer as well as the orifice tube?
Old Mar 11, 2016 | 05:49 PM
tjc transport's Avatar
tjc transport
i ain't rite
3 lbs, or 48 ounces of R-12
Old Mar 11, 2016 | 05:50 PM
Christopher Layton
Is that the same for r-134a?
Old Mar 11, 2016 | 05:54 PM
tjc transport
i ain't rite
no idea, i do not use 134A in R-12 systems. i put in what the system was designed for.
Old Mar 11, 2016 | 06:43 PM
sgip2000's Avatar
sgip2000
For 134, you'll want to use 80-90% of the R12 amount.
Old Mar 12, 2016 | 08:18 AM
rla2005's Avatar
rla2005
Personally I would not downgrade to an inferior refrigerant. But if you feel the need to do so the Ford manual states 33 oz. of R14a for a 1995 F series truck (factory R134a).
You will also need a red orifice tubes versus the blue one that should be in there for a R12 system.
I highly suggest you change the receiver/drier to on suitable for R134a.
Be aware the hoses on your 1990 do not have liners in them. The smaller R134a molecules will permeate the hoses much faster, meaning leak out. Add in 20+ years of service they are already leakers, R134a will make the problem worse.
Old Mar 12, 2016 | 08:24 AM
tjc transport
i ain't rite
agreed. that is the main reason why i do not convert. plus the R-12 just cools better. my truck blow sub 40 degrees out of the dash outlets. i have never seen a conversion cool any better than 55 degrees from the outlets..
Old Mar 12, 2016 | 08:47 AM
'89F2urd's Avatar
'89F2urd
Yea good idea to replace the drier at the very least, they can be the cause of a poorly functioning system because they get clogged up.
134 may be inferior, but a properly functioning system will still freeze you out.
Old Mar 12, 2016 | 08:59 AM
miguel.in.az's Avatar
miguel.in.az
May as well overhaul the whole system and get all 134a parts, it's not that expensive and it will keep you cool for a long time
Old Mar 12, 2016 | 01:08 PM
rla2005's Avatar
rla2005
In all honesty you will find thousands of threads on this topic. Some have no issues with a cheap and dirty conversion, others not so much. My theory is if you plan to keep the truck, rebuild the A/C system the right way.
Personally I still would not do a R134a conversion. New hoses, yes. New condenser? probably not because the older systems are not as prone to clogging up with no way to clean them as the more efficient parallel flow version on later models. New receiver/drier, orifice tube, compressor, lines and a thorough flush...good to go.
I do my own A/C work and have made my fair share of bad decisions based on money and learning curve. Your mileage may vary.
Old Mar 12, 2016 | 03:47 PM
GuitarJesus's Avatar
GuitarJesus
Ford had a TSB where the OBS R134a capacity was raised up to 38oz
Old Mar 12, 2016 | 04:07 PM
Christopher Layton
Ok, so I was able to verify that the system does not leak with the gauges and I put 36 ounces of 134a in which is 75% of what you guys recommended for r-12.
The compressor comes on and the air output is cold. Is that ok that I only put in 75% or is that too low and will that create any problems?
Old Mar 12, 2016 | 08:57 PM
Christopher Layton
Anyone know about diagnosing a turn signal problem on this truck?
They're not blinking (none of them)
When you turn the signal just stays solid lit.
The hazard signals however work properly.
Old Mar 13, 2016 | 08:28 AM
tjc transport
i ain't rite
sounds like a bad flasher. it will either be in the fuse panel, or on the back of the fuse panel. don't remember where exactly on the 90.
Old Mar 17, 2016 | 12:15 PM
Christopher Layton
How do I remove the rear door lock actuator?
Anyone know how to remove the rear door lock actuator on the 1990 F350?
