Offroad & 4x4
what makes a highboy a highboy?
Old Aug 11, 2003 | 08:49 PM
muscletruck7379's Avatar
muscletruck7379
Question what makes a highboy a highboy?
what exactly makes a highboy a highboy? I know that they were lifted , but how were they lifted (blocks, stiffer springs)? I also heard somewhere that they had an updated steering that was more suitable for off road use.
Old Aug 12, 2003 | 06:54 AM
72f100's Avatar
72f100
The highboys had a few unique things about them. In the front they have positive arch springs where the 78-79 lowboys had zero arch. The highboy springs are the same as a 2 or 4" spring (can't remember which) for a lowboy. In the back they had pertty heavily arched 2 1/4" wide springs and 4" cast iron blocks from the factory.
Another unique feature is a divorced mounted transfer case. This does hurt you a bit in ground clearance in the middle but a divorced case is a bit stronger and when you consider it's a divorced mounted NP205, it's an incrediblly stout case.
As far as steering goes, they have the perfect setup for wheeling. It's a hydraulic assisted steering. Basically it's a manual steering gear box connected to a hydraulic control valve in the drag link. This valve controls fluid pressure to a hydraulic cylinder mounted on the axle. This setup takes almost all of the stress off the steering box and put it on the cylinder mounted on the axle. This is very similar to the Rock Ram system people pay $1000+ for. It works really well and is easy to modify and make stronger.
Old Aug 12, 2003 | 01:12 PM
proeliator's Avatar
proeliator
The short answer is: Any F-250 4x4 between the years 1967 and early/mid 1977. I know, its a shock.
Old Aug 12, 2003 | 08:16 PM
muscletruck7379
ok, thanks for the info. one more question then, is there any indication in the vin or something that can be used to identify a highboy, or is parts the only way to tell?
Old Aug 12, 2003 | 11:59 PM
nbaff's Avatar
nbaff
if the vin verifies that it is a 67 through 77 1/2 F-250 4x4 then it is a highboy. I think highboy is actually a nickname and not a offical term. I will get corrected quickly if that isn't right.
Old Aug 13, 2003 | 12:02 AM
proeliator's Avatar
proeliator
Your quickly correct.
Old Aug 13, 2003 | 01:12 AM
muscletruck7379
oh-ok, answers that, did they all have the np205's?
Old Aug 13, 2003 | 12:45 PM
proeliator's Avatar
proeliator
Nope, some of the earlier ones had Dana 24s. The 205s came in at '73. Dana 24s are just as good, gear driven units.
Old Aug 13, 2003 | 03:05 PM
79 Pulling Ford's Avatar
79 Pulling Ford
Some of the highboys also had New Process 203's in them also.
Old Aug 13, 2003 | 04:02 PM
proeliator's Avatar
proeliator
yup, the later ones. I don't care what anybody says....chain drives suck.
Old Aug 13, 2003 | 11:52 PM
kspilkinton's Avatar
kspilkinton
Yup... had a '73 Highboy w/ a 360, Np 435 4 speed and the NP 203 "full time" chain drive... always confused people when I drove up and the front drive shaft turned in "2Hi."
-Kerry
Old Aug 14, 2003 | 06:05 PM
muscletruck7379
-Kerry
hey man, what type of mpg were you getting with that setup?
also, I have heard of lowboys too, are they just literally lower?
Old Aug 14, 2003 | 06:24 PM
Texan1983's Avatar
Texan1983
hey i have a 203 i am eventually going to swap out for a 205 but was wondering since mine has been converted to a part time t-case, if i was to break the chain i could still drive it in 2wd right?
Old Aug 14, 2003 | 11:42 PM
kspilkinton
I had a whopping 8mpg. Didn't matter what the speed or how far. It always got 8.
Only in rear wheel drive if I get how you stated the question, and that's regardless of the hub conversion. The chain was set up to the front axle, the rear axle was connected via U-joints and shafts to the xfer case and tranny. So breaking the chain will screw up the front end drive, not your rear. If you disconnect the rear drive shaft and have a good chain you can drive in front wheel drive. Lock in the hubs (or don't if you have an original 203 setup) and drive away without the rear drive shaft.
-Kerry
Old Aug 15, 2003 | 01:10 AM
Texan1983's Avatar
Texan1983
yea thats what i mean't i kinda like the 2wd low feature when converted, only thing that sucks is the chain drive. but is does have a lower gear reduction in low range than a 205. but i am still worried about the chain, acually i have heard the chain is not the weak link in these anyways, it's something else i can't remember.
