400 build
Old Mar 11, 2016 | 08:35 AM
79f1dy's Avatar
79f1dy
400 build
Has any one build a 400 with tmeyer pistons and had there stock heads decked to the max? Im just curious what kind of compression ratio it comes to? And what octane gas to run?
Old Mar 11, 2016 | 08:57 AM
jbehuniak's Avatar
jbehuniak
You're talking a 0 deck height?
Old Mar 11, 2016 | 12:16 PM
buckin69bronco's Avatar
buckin69bronco
The deck height of Tims pistons is listed to be 0 and he says they have a 13.3cc dish. Stock heads are about 76cc for the chambers...
Milling the head .005 nets a 1cc reduction in chamber volume... That said, it is suggested that for every .01 you take off the heads you should take .01 off the intake (intake to head surface) and .0143 off the intake end surfaces.
Tim's pistons give about a 9.4:1 ratio with stock heads
I'm going to throw out a max of .050 for decking the heads, some say the max is more and some say it is less.
.050 off the heads will give you 67cc chambers and that will give you 10.28:1
10.28:1 with these open chamber heads puts you well out of 92 octane.
With the cost of machining the intake and heads added to the cost to rebuild the heads I would think you would be better off buying some new heads with small quench chambers. It is possible to run 10:1 and more with aluminum quench chamber heads.
Old Mar 11, 2016 | 12:24 PM
somethingclever's Avatar
somethingclever
i agree with buckin bronco....no reason to go above 9.4:1 with an open chamber head....especially if in a heavy truck.
Just clean up the heads minimum amount and run tmeyer pistons and be done.
Old Mar 13, 2016 | 07:33 PM
1977FORDF150's Avatar
1977FORDF150
Project bronco.com goes over everything you need to know & more on this engine,
bleeds blue
Feb 4, 2019 01:07 PM
dutchlincoln79
17
Mar 16, 2008 03:47 PM
cruz76
Apr 19, 2007 01:24 PM
80`F-150
May 12, 2005 11:15 PM
myred79
21
Jun 28, 2003 12:39 PM
