1996 460 Occassional No Start/No Spark
Old 05-19-2016, 10:17 PM
ShawnV's Avatar
ShawnV
ShawnV is offline
What about the calibration number matching that I'm reading about? Mine is a 6-98d and I can't find that anywhere. It looks like advance auto and autozone both have the F6 BSA but their calibration numbers don't match mine.
- Shawn
  #32
Old 05-20-2016, 08:35 AM
subford's Avatar
subford
subford is offline
The 6-98d has a missing part and are you sure it had a d in it or was that some other letter.
These are the only calibration numbers I come up with for your year and engine.
  #33
Old 05-20-2016, 10:03 AM
ShawnV's Avatar
ShawnV
ShawnV is offline
Thanks for your help.
This is what I'm seeing on the door jam
  #34
Old 05-20-2016, 10:38 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Nevermind...asked a dumb question.
  #35
Old 05-25-2016, 06:06 PM
ShawnV's Avatar
ShawnV
ShawnV is offline
I went ahead and ordered a new Cardone PCM for the truck. It arrived today and I installed it. The truck started right up and it runs amazingly now! You can barely even hear the engine now.
I drove it around 10 miles, but then it wouldn't start when I came out of the FLAPS. I pulled the Spout and it started right up. It died on the way home and I had to pull the spout again to get it home.
Should I try to replace the spout connector at this point? I'm impressed with how the truck runs now, if I could just get this ignition stuff settled.
Thanks,
- Shawn
  #36
Old 05-25-2016, 07:24 PM
subford's Avatar
subford
subford is offline
Pull the SPOUT out and start the engine and check the base timing with a timing light. Should be 10 Deg BTDC.
If the timing is OK check the SPOUT wire in the harness for a short to ground between the SPOUT connector and the Computer.
If no short is found replace the PIP sensor in the distributor.
  #37
Old 05-25-2016, 08:33 PM
ShawnV's Avatar
ShawnV
ShawnV is offline
I'm not equipped to test timing, or would I even know how. What else might cause timing to be off?
Also, will replacing the distributor replace the PIP sensor? I foolishly installed a MSD and wish I had gone motorcraft.
Thanks,
- Shawn
  #38
Old 05-25-2016, 08:48 PM
subford's Avatar
subford
subford is offline
Yes replacing the distributor will replace the PIP sensor.
But I would not throw parts at it until you check the timing.
A timing light should not cost that much and if you replace the distributor you will need one anyway.
  #39
Old 05-25-2016, 08:58 PM
ShawnV's Avatar
ShawnV
ShawnV is offline
Is that something I could take it to a shop to check? I don't know how to test timing.
I already replaced the dist. when I got the truck and started having issues with it. So that might be part of my problem.
- Shawn
  #40
Old 05-25-2016, 09:17 PM
subford's Avatar
subford
subford is offline
Yes you can take it to a shop to get the timing set.
  #41
Old 06-15-2016, 08:04 PM
ShawnV's Avatar
ShawnV
ShawnV is offline
I had a friend of mine replace the entire distributor yesterday. It was a super easy part to replace, but he knew how to make sure the new one when in the same as the old one came out. I was not comfortable doing that.
But, I've driven the truck three times so far and have not had any issues. Before I was having issues every time I drove it, so I'm keeping my fingers crossed.
The new PCM is wonderful and well worth the time replacing it (even if that was not the entire problem), and the truck is running very well.
Thanks again!!
Shawn
jakenney
15
03-07-2012 03:44 PM
justtin00j
17
03-25-2011 03:51 PM
BigJ5656
09-15-2009 07:43 PM
Nathan Plemons
23
06-22-2009 10:57 AM
smooth
03-04-2009 05:19 PM
Quick Reply: 1996 460 Occassional No Start/No Spark
