302 wont rev
Old Mar 18, 2016 | 09:03 PM
  #31
Redneckfordf2502002's Avatar
Redneckfordf2502002
I just today was going to update that I found a new truck at the local junkyard that just so happened to have a C6 302 with a perfect kickdown cable.
I have to clean it up then will install it come Wednesday also make sure I adjust it perfect. $5 for it I don't think was a bad deal at all.
Trav
Old Mar 19, 2016 | 07:40 AM
  #32
Mudsport96's Avatar
Mudsport96
Awesome! Can't wait to hear.
Old Mar 29, 2016 | 11:39 AM
  #33
Redneckfordf2502002
Ok so sorry it took so long to update but I had to get a new computer and the day I got it I was busy getting rid of my Chevy for a Bronco of my own.
The trans cable I believe I got adjusted correctly but it seems like it doesn't downshift still. It defiantly helped a little bit though. I may have to play with the adjustment to get it just right so that it downshifts on time plus the shift points I need to mess with.
I better learn these C6s well since my new to me bronco has a C6 also. LOL
Trav
Old Mar 29, 2016 | 10:25 PM
  #34
'89F2urd's Avatar
'89F2urd
Honestly, if the thing is slow and can't hold its own in 3rd at 55-60....downshifting to 2nd will do no good. I had a diesel (slow as hell) c6 with no kick down and it wasn't an issue.
Old Mar 30, 2016 | 12:09 AM
  #35
Willz74's Avatar
Willz74
Amongst my chevy loving friends the 302 in my 91 has earned respect for making the tach needle do a lap when the gas pedal got stuck to the floor so they aren't rev limited diesels that being said my only thoughts are the coil because I've had one that would limit the motor like that or you don't have the power to go faster
Old Mar 30, 2016 | 08:12 PM
  #36
Lead Head's Avatar
Lead Head
The EFI 302 in your '91 is most certainly limited. Partial fuel cut starts at ~5200 RPM, full fuel cut by 5400 or so.
Old Mar 30, 2016 | 08:56 PM
  #37
Willz74's Avatar
Willz74
We'll the tach must've been lying then I pushed the clutch at about 5-6000 rpms I didn't shut the motor off until the needle went back to 0 I did learn they don't return when that happens they just stop at zero
Old Mar 30, 2016 | 09:26 PM
  #38
Lead Head's Avatar
Lead Head
Tach glitch. The computer "thinks" millions of times per second. It will not let the engine exceed the preset rev limiter under any condition.
Old Apr 18, 2016 | 01:44 PM
  #39
Redneckfordf2502002
Ok so sorry for a long response with this thread.
The truck seems to hold its own great when pulling found that out the other day but empty it acts like always. It was downshifting properly with the load and at the right RPM (3500 WOT going to 4300 rpm) but empty it still doesn't downshift except once in a while turning 2000rpms going up this one hill.
When it downshifts this truck moves big time.
I have tried playing with the cable to see if it helps but no such luck.
I did find yesterday while doing the oil change the coil wire touching metal so possibly this was causing the distributor to loose its full potential of spark from the coil.
I will update and say that the transmission pump is weak and the trans does have its issues which is the reason for a C6 sitting aside right now waiting to be rebuilt but I need the bronco going before I can put my F150 down to do it as I rarely have a good day off from work.
I don't feel confident adjusting the shift points on this transmission since it is working (not the best but it gets me to and from work) right now and like I said I can't have it go down not having a second truck yet.
Trav
Doc150
Jul 26, 2013 10:02 PM
c_rossman
15
Jan 31, 2010 10:18 PM
savage250
Mar 1, 2005 04:00 PM
lilwally_90ford
Feb 3, 2005 03:32 PM
araiderfan2001
May 5, 2003 12:50 AM
