Where can that flasher be?
Old Aug 11, 2003 | 06:25 PM
cmask's Avatar
cmask
I have a ford van e150 econoline 302 engine.
My turn signal flasher clicks a few times and stops. Its as though it needs a rest period (ignition off) before it will resume flashing again. It has never glowed any lights during this short term clicking.
Suspect it is just a bad flasher I hope!
Trouble is, I can't find it, I hear it during the short duration it decides to click, but can't see much under the dash much less getting my hand up in there to pull it off because of so much stuff.
I though I found it, but it turned out to be the emergency flashers which work fine on all bulbs.
Where could it be?
Thanks for any help!
Charles
Old Aug 11, 2003 | 06:44 PM
rustydog628's Avatar
rustydog628
look on the BACK side of the fuse block right behined the hazards flasher
Old Aug 11, 2003 | 08:05 PM
cmask's Avatar
cmask
Hi rustydog,
Doesn't seem to be anything but smooth metal behind my fuse block. That's all I could feel scraping the skin off my hand doing it.
The whole block is mounted on a steel plate. I saw in the manual where the flashers were supposed to be in the fuse block, but boy my two isn't.
All it has is fuses and the square metal thing what ever that is. That metal thing is not the flasher cause I pulled it out and still heard the flasher ticking.
I found my hazard flasher pluged into a wire that was just laying up near the head light switch up in the dash , I had to use a lot of pull so I could get it pulled down just bearly enough to grasp the plugend with one hand and pull off the flasher with the other.
I don't think I'm going to be so lucky with the regular flasher. It has finally stop clicking now and that was my last hope in pinpointing it's location.
Thanks
Charles
Old Jun 8, 2004 | 08:33 PM
HDerector's Avatar
HDerector
Flasher
The flasher is located directly under the fuse box. The service Mgr. said behind the box, but is completely visible
Old Jun 8, 2004 | 09:03 PM
bremen242's Avatar
bremen242
actually, the turn signal flasher is on the front of the fuse panel, under the back cover. To access the 4-way flasher, you must unbolt the fuse panel from the firewall, and then the flasher is mounted on the back.
Old Dec 24, 2004 | 02:56 PM
HDerector's Avatar
HDerector
Fuse Panel
Can anybody please tell me if the if the Dome Light, Speedometer is on the same curcuit. If so where is the fuse. We are talking about a 1993 Ford E 150 V8 Thank You
79BRNC
Sep 21, 2011 10:43 AM
thetileguy
Aug 30, 2009 12:43 AM
whitesdford
Jul 26, 2008 11:09 AM
rocknut
Mar 20, 2007 12:32 PM
montangrunt
Aug 12, 2003 07:56 AM
