Offroad & 4x4
Front traction bars
Old Mar 7, 2016 | 09:10 PM
mroth2008's Avatar
mroth2008
Front traction bars
I trying to figure out how to run my traction bars up front with leaf springs. What have you guys done? My truck is a 1994 F250, F350 running gear, 7.3 idi turbo warmed up abit, 5 speed 4.10's, with a home made 1356/1345 doubler. I'm worried about having lots of wrap since the front is pretty soft. Its currently on 35's but plan on running 40 inch swamper's.
Old Mar 7, 2016 | 09:56 PM
82F100SWB's Avatar
82F100SWB
I would be leaning towards a single anti wrap bar due to packaging. Something like this:
Old Mar 8, 2016 | 06:57 AM
projectnitemare's Avatar
projectnitemare
I agree with the previous. Do the same for the rear if you want one. That's about the most off road friendly way of doing one. Doesn't bind as bad, takes up less space and doesn't kill ground clearance.
Old Mar 8, 2016 | 09:41 AM
tjc transport's Avatar
tjc transport
i ain't rite
i can't see how this will work properly. the bar will want to move the axle forward under compression, but the spring and shackle will want to move the axle rearwards under compression.
Old Mar 8, 2016 | 09:54 AM
projectnitemare
That example isn't the best, really there should be a shackle at the frame mount to take care of that. That one may be on a shackle but it's not clear to tell for sure.
Old Mar 8, 2016 | 10:38 AM
tjc transport
i ain't rite
exactly what i was thinking, the rear of the bar has to be shackle mounted to work WITH the springs, not solid.
Old Mar 8, 2016 | 06:00 PM
mroth2008's Avatar
mroth2008
Thank you! I googled the crap out of it and their isnt much around, unless I have toyota.... I will post pictures up when I have everything done.
Old Mar 9, 2016 | 12:06 PM
82F100SWB's Avatar
82F100SWB
I'm pretty sure that one is shackle mounted, I was just looking for a good clear picture.
That bar looks to be built from one of RuffStuff's kits.
Antiwrap/Traction Bar Complete Kit - RuffStuff Specialties
Old Mar 9, 2016 | 12:51 PM
projectnitemare
.250 wall is pretty stout for a traction bar. Not a bad price either for a complete kit minus a cross member to mount it to.
Old Mar 9, 2016 | 04:55 PM
mroth2008's Avatar
mroth2008
I would rather build it myself, I take pride in doing it myself as much as my gf hates it's "Why does everything have to be custom?!"
Old Mar 9, 2016 | 05:21 PM
projectnitemare
Yeah I do a lot of my own stuff too. Either it has to be custom because nobody makes it, I don't like what's available, or its not strong enough. I will admit, for that price I'd buy that kit over making one
Old Mar 12, 2016 | 10:56 AM
hav24wheel's Avatar
hav24wheel
A traction bar HAS to be stout. you would be amazed at how much twist s axle can actually have with large tires and good traction. I was using the Wagoneer to pull trees out of the ground, and the front tires would actually bob off the ground.. Bent my 1/4" thick bar. Had to sleeve it for extra strength.
crucialprospect
May 23, 2018 05:26 PM
NMB2
30
Mar 30, 2012 01:12 PM
oreocreaming
Nov 29, 2010 06:42 PM
bartn98
Dec 31, 2008 06:37 PM
Franken-Truck
Offroad & 4x4
23
Oct 10, 2005 10:07 PM
