need help
Old Mar 7, 2016 | 02:51 PM
miller56's Avatar
miller56
need help
I have a 1978 f250 with a v8 400 in it and last spring i started a rebuild to fix it up i took the cab and bed off and now want to start the engine on the frame stand alone starting when i got it set up i tried to start it and it will turnover but has no spark at the spark plug or Distributor has new ignition coil, wiring, to the plugs and coil new spark plugs and new pick up coil and still no spark any help on this issue will be greatly appreciated
Old Mar 7, 2016 | 07:43 PM
grinnergetter's Avatar
grinnergetter
Pretty tuff to diagnose that when we have no idea how you wired it up.
Why do you want to start it up now?
Welcome to FTE!!!
Old Mar 7, 2016 | 08:26 PM
dlburch's Avatar
dlburch
https://www.ford-trucks.com/forums/1...l#post15231311
Old Mar 7, 2016 | 09:22 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As for the push button start switch. If you don't want to repair the wiring to use the key switch, one wire from the push button needs to go to a constant 12 volt hot and the other wire needs to go to the small "S"terminal on the starter solenoid.
And....
The GREEN with RED stripe wire coming from the cab connects to the 'I' input of the regulator.*Note*that if this truck was originally wired for gauges, the GREEN with RED stripe wire is sourced differently. If that's the case, you should make that clear.
The STA stud on the back of the alternator connects to the 'S' input of the regulator. If you have a factory electric-assist choke, the STA stud also branches to that.
The 'F' output of the regulator connects directly to the FLD stud on the back of the alternator.
The large output terminal of the alternator (sometimes labeled BATT or B+) connects to the battery side of the starter solenoid through a fusible link as well as the 'A' input of the regulator.
wavetrain75
18
Sep 21, 2018 11:13 PM
Fistfull of dollars
16
Dec 26, 2017 11:57 PM
72CC428
Electrical Systems/Wiring
Dec 27, 2012 06:51 PM
markjw
Jul 11, 2006 12:28 AM
bagrove6202
Oct 25, 2004 12:17 PM
