have a problem with truck's lights...?
Old Mar 7, 2016 | 05:13 PM
eriebasin's Avatar
eriebasin
Hi Hmilycar:
I have seen a few other posts about this topic; it is a design flaw on the early models. Someone will correct me if I'm wrong, but there are two "solutions" (that I'm aware of); you can turn on the lights during the daytime, but that may dim other things like the clock and whatnot such that you can't see them; or, add aftermarket lighting to the dash. I hope he enjoys his new truck nonetheless!
MODERATOR NOTE: THIS POST IS IN RESPONSE TO A NOW REMOVED POST BY A SPAMMER REGARDING DASH LIGHTS.
Old Mar 9, 2016 | 06:56 PM
hammer65's Avatar
hammer65
Is the little dial turned to high?
Old Mar 13, 2016 | 01:24 PM
SBV45's Avatar
SBV45
My 09 explorer has this in the owner manual:
PANEL DIMMER CONTROL
Use to adjust the brightness of the
instrument panel when exterior
lights are on.
• Rotate the thumbwheel from left
to right to brighten the
instrument panel.
• Rotate the thumbwheel from right
to left to dim the instrument
panel.
• Rotate fully to the right (past detent) to turn on interior lamps.
• Rotate to the left position (past detent) to turn off the interior lamps
and to disable the illuminated entry feature. When the control is in the
far left position, it acts as a dome lamp defeat/override.
Note: If the battery is disconnected, discharged, or a new battery is
installed, the dimmer switch requires re-calibration. Rotate the dimmer
switch from the full dim position to the full dome/on position to reset.
This will ensure that your displays are visible under all lighting
conditions.
Is your F150 have the same wheel? My F-150 has a rocker type switch that has the same functionality.
Wicked Endings
13
Nov 9, 2010 06:54 PM
1 Excursion camper
2009 - 2014 F150
Oct 18, 2010 10:42 AM
fordguy712
Nov 5, 2008 07:49 AM
1972ford_f-100
May 28, 2005 11:34 AM
monacm2
Jun 12, 2004 12:11 PM
