Detroit Locker Thoughts ?
Old Mar 6, 2016 | 05:48 PM
tr0y's Avatar
tr0y
I recently moved from the desert southwest to Minnesota, we went from dry dusty ranch to wet, muddy, grassy farm. We have a 2wd 99 F350 long bed dually as a ranch truck and were going to use it more in the winter here as to not let the newer nicer trucks be drenched in salt all winter long.
The truck has what I think should be a factory limited slip rear end, but it just sucks when it hits any mud, snow , ice anything where one wheel is losing traction. I don't really want to have to go to mud tires as we run on the highway quite a bit and don't want the noise, i've run mud tires before on other trucks and don't want to here.
Is this a situation that maybe adding a Detroit Locker might help ? Next year for winter we are going to add snow tires or maybe even studded snows ...
I am not real concerned if it chirps a tire of makes a bit of noise from time to time as long as we are not breaking things.
Can anyone from lands of snow , Ice, Mud, Wet Grass and fields give me some insight ?
Old Mar 6, 2016 | 06:26 PM
F350-6's Avatar
F350-6
Not from the lands of snow and ice, but I've been stuck in wet grass on dry fields before. A little mud and I'm going nowhere. I can rock back and forth, throw stuff under the tire, all the tricks and won't go anywhere. The wife can pull me out with her 4wd without even so much as spinning a tire.
Yes I think a locker would help. Just keep in mind that if you're on iffy traction and then suddenly you gain a bunch of traction, it can make the back end squirrelly and loose.
Old Mar 6, 2016 | 07:27 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Having the rear axles locked together on ice is a recipe for ending up in the ditch. It will help to get you unstuck when you are facing the wrong direction in the median though.
Old Mar 6, 2016 | 09:07 PM
SRBF150's Avatar
SRBF150
I would go with the TrueTrac. Better manners and meant for towing.
Old Mar 6, 2016 | 09:53 PM
z31freakify's Avatar
z31freakify
Just load 1,000lbs behind the rear axle or close enough to the tail gate and you wont have a problem in wet, muddy, and slippery icy conditions.
Old Mar 6, 2016 | 10:25 PM
takotruckin's Avatar
takotruckin
The Tru-Trac would be a much better option for snow and ice.
Old Mar 7, 2016 | 12:06 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I live in the land of ice and snow (Donner Summit is my front yard) plus I got my license in MN. I also vote for the Tru-Trac over the locker for the reasons mentioned.
Unless things changed there in the 40 years since I bought my first car, studded tires were illegal when I worked at a service station there so that may not be an option for you.
Old Mar 7, 2016 | 07:12 PM
F350-6's Avatar
F350-6
I do this for snow and ice when we have it, but I'll say it's definitely a no go for wet and muddy (off pavement). 1,000 lbs in the back just makes the right rear tire dig a hole faster in muddy conditions. Been there, done that.
Old Mar 31, 2016 | 10:36 PM
BigRed1Ton's Avatar
BigRed1Ton
Take off the outside dual tires. Run some traction snow tires on the rear singles, and put some sand bags or hay bales in the bed. Carry chains. The outside duals cut their own track and slip in ice and snow. The factory limited slip will be fine, if you use this setup. Works on Donner for me.
Old Apr 1, 2016 | 01:04 AM
Jim Timber's Avatar
Jim Timber
I've been driving a Detroit locker in my Tahoe for the past 80K on mostly highway and have never ended up in the ditch - but I also don't let the Mrs. drive that truck in bad weather because she'd flip it on ice. Lots of white knuckle miles in sleety storms, and it'll slide the rear in the rain without trying too hard. I've thought about pulling it out if we keep the truck for a back-up, and I've thought about leaving it in if I keep it for a farm truck (which I'm leaning towards, but the Mrs. seems to think we should keep it at the house as a spare).
Truetrac gets my vote whole heartedly. If you don't want that, then go for an ARB air locker.
Old Apr 10, 2016 | 05:02 PM
Dude-Ford's Avatar
Dude-Ford
I'm in SLC and the eaton tru trac does a pretty dang good job. I run 80w90 in it out here and when I go to OKC in the summer I put 85w140 in it. I can tell a big difference in the mud and snow bit when it's icy it'll damn near make the truck go side ways.
Old Apr 10, 2016 | 06:10 PM
onebadv2's Avatar
onebadv2
can the factory limited slip be rebuilt? if so, what is the parts cost vs. tru trac purchase cost? would the labor be about equal? I have the factory limited slip an it does nothing for me.
Old Apr 10, 2016 | 06:24 PM
Dude-Ford's Avatar
Dude-Ford
Funny story, when I was 16, I rolled my dads 2002 blue 7.3 on its side driving on some slush being a knuckle head with a bunch of my buddies. Will never forget my pops look of disappointment when he came and pulled it back up right. Truck still ran stronger than hell after that too, testament to how strong these trucks are.
Old Apr 10, 2016 | 06:59 PM
Jim Timber's Avatar
Jim Timber
Oil starvation pretty much kills the fuel supply so it doesn't run dry. Not exactly a designed feature, but a happy accident none the less.
I'm also curious about the factory LSD's. Seems like if you could stuff another clutch in them and tighten them up, it could be a cheap way to get closer to an ideal rear bias. I've never done it, or even known of anyone who did, but that was mentioned in years past as a way to improve the performance of the 9" fords IIRC (it might have been the pre-gov-exploder GM's).
Old Apr 10, 2016 | 08:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I redo my factory limited slip differentials. The 10.25 and 10.5 Sterling axles are a piece of cake....and setting them up tight is REALLY easy and effective.......until the spider and side gears eat themselves up. I don't recommend doing that with a daily driven vehicle that may tow. The growl during turns is mind numbing. Yes, the parts to rebuild the factory limited slip are available through Ford.
