First Head Gaskets, now more problems. Help!!
Old Mar 6, 2016 | 11:01 AM
mverdill's Avatar
mverdill
Hi All,
First off, let me say that I am new to diesels so pardon my ignorance or stupid questions.
I bought an '05 F250 6.0 Diesel in December last year. Had a tremendous amount of coolant loss, so I ended up doing head gaskets, ARP studs, new oil cooler, blue spring update and a few other things. I had the heads re-surfaced and put everything back together. The coolant loss has cleared up but now I'm having more trouble.
I was towing a 3,000# trailer today and noticed that when pulling up a hill there was alot of black smoke coming out of the exhaust and the truck did not seem to have much power. Also, the turbo seems very loud and I noticed that when letting off the accelerator, there was a "put, put, put" noise as I slowed down. I used to town this trailer with a V8 gas Dodge and it pulled much better, so I know that something is wrong. The EGR has already been deleted on this truck.
I'm not sure if the turbo is bad or what? I checked the turbo when it was off and didn't notice play in it, but I didn't clean it or open it up.
Please help! Any suggestions would be great.
Thanks.
Old Mar 6, 2016 | 12:32 PM
bobv60's Avatar
bobv60
What is your boost gage reading? Could be a torn or blown off boot. craked cold side CAC tube if its still plastic. Or stuck turbo
Old Mar 6, 2016 | 12:35 PM
timmytoes's Avatar
timmytoes
Have you checked your CAC boots for tears or holes?especially on the bottom side of the lower one. If you have a leak in those on the hot side, those are classic symptoms. Elimate the easy stuff first.
Old Mar 6, 2016 | 01:04 PM
BLADE35's Avatar
BLADE35
Better check the sensor to
Sounds like the turbo is stuck if your getting that cha cha cha sound upon go pedal lift
Mpg down to I assume
Old Mar 6, 2016 | 01:40 PM
mverdill's Avatar
mverdill
I have checked the boots for tears and they look fine. My boost gauge is reading over 20 sometimes higher.
Yes, my fuel mileage is terrible - under 10MPG.
Which sensor are your meaning to check??
Thanks
Old Mar 6, 2016 | 06:17 PM
KDAVID1's Avatar
KDAVID1
I'd start with the EBP, unplug it and see how she does. Also clean the ebp tube and map tube.
jlh542
Nov 6, 2013 01:33 PM
WH 6.0
Oct 9, 2012 10:17 PM
Slickie123
Mar 29, 2012 01:30 PM
Stu206
Jul 28, 2011 04:59 AM
Towman1981
Mar 14, 2007 04:59 PM
