More Electricity
Old Mar 6, 2016 | 07:21 AM
bcamill's Avatar
bcamill
More Electricity
1983 F100 302, AOD. I am looking to get more amps. I have installed two 12 inch fans on the outside of the condensor to assist with the A/C. If I have the A/C on and the lights I lose the directionals at idle at a stop light. I have tested the out put and it drops dramatically at that idle sped. May I get a different voltage regulator or do I need a different alternator? My local supply does not have anything bigger than the 65 amp. If I put in one with more, do I need to make any other changes? Where may I find a larger one.
Old Mar 6, 2016 | 08:50 AM
reamer's Avatar
reamer
What kind of "extra" fan are you using (and why)? sounds like it has a HUGE draw on the system...
Old Mar 6, 2016 | 09:15 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
An alternator is only capable of sustaining its rated output.
Run it higher than that for long, the diodes will fail and the windings will short when the insulation melts.
I'd be looking at a more efficient fan.
You could search this forum for '3G alternator upgrade'
Old Mar 6, 2016 | 10:04 AM
bcamill's Avatar
bcamill
I am using the fans to cool the condensor. In AZ we get up to 115 in the summer and the A/C would not operate as the pressure would build too high. I will have to look for an alternative.
Old Mar 6, 2016 | 10:33 AM
Rusty_S's Avatar
Rusty_S
Only thing I could advise is look into a 3G alternator upgrade. I cant remember which car but theres a car you can get the alternator from that is a straight bolt in. Just transfer your current pulley and shim it with a thin washer and youll be good to go.
I currently don't need it but my stock truck you come to a idle you actually can hear the A/C or Heater fan actually slow down at full idle. But its doable and not worth spending extra cash at this point for this upgrade when the only upgrade I have is two 40ish Watt LED flood lights mounted up front.
Old Mar 6, 2016 | 01:10 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
If I recall, it is from the Taurus.
I had a '97 Ranger 2.3l which i used for volunteer fire/ems and ran an old school rotator lightbar, siren, etc. which caused huge power draw. I consulted a fairly large LKQ wrecking yard locally and they cross-referenced a higher amp alternator which was "plug-n-play". It might be worth a phone call or two.
Old Mar 6, 2016 | 01:22 PM
Rusty_S's Avatar
Rusty_S
That's right its from a Taurus, I think a 92-93 if I am not mistaken.
Old Mar 6, 2016 | 01:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you need the 7" C-C mount for Windsor engines they come from the 3.0l V-6
For 4.9 and 460 engines get the 8.25" mount from the 3.8.
Taurus, Sable and Aerostar I believe...
Old Mar 6, 2016 | 03:29 PM
Franklin2's Avatar
Franklin2
Something simple you could do is increase the idle speed on the carb. When I first put the snowplow on my old f150 it would not pick the plow up at idle. I just turned the idle up a little bit and it worked fine from then on.
This would also make your A/C work better in that hot weather. Just don't turn it up too high where it really slams hard when you put it in drive, or you have two feet on the brake pedal holding it back at a stoplight. Just a little bit is probably all you need.
Old Mar 6, 2016 | 05:12 PM
WhatsAChevy?
So, increasing idle speed at the carb will increase alternator amperage output for long periods of time? I don't think I'd be relying on that. Way too many variables with that theory IMO. My 84 F150 with a 302 and a Western plow works great with a 145a alternator without any slamming,hopping or jumping.
No readjusting the carb when you d/c the plow for the summer months either. I'd imagine that if you are into babysitting your carb, this would be a viable option, or a band-aid on a severed arm.
Old Mar 6, 2016 | 09:08 PM
GypsyR's Avatar
GypsyR
It isn't "theory", it's a method of dealing with the known low RPM low-charging propensities of Ford 1G and 2G alternators. Easily proven by use of an ammeter. These days many alternators are controlled by the powertrain computer. One of the computer strategies is to raise engine idle RPM's (withing limits) during periods of high electrical power draw. Even with with earlier fuel injected systems where the alternator wasn't under direct computer control idle could be raised on demand due to power draw.
For years people have co-opted AC throttle "kickers" for the same purpose.
Turning up the idle a bit with a screwdriver is simply the stone age equivalent.
I used to have an '83 and equipped it with a 100 amp "large case" 1G alternator. Which helped nothing. The maximum amp rating of an alternator doesn't help with low RPM charging. It wasn't until the introduction of the 3G when Ford really rectified the low RPM charge issue.
Heh, rectified. Yep.
Old Mar 7, 2016 | 08:22 AM
bcamill's Avatar
bcamill
Franklin 2, I do find myself putting the truck into Neutral at times when waiting at a light. This does solve the problem for the moment.
Old Mar 7, 2016 | 08:23 AM
bcamill's Avatar
bcamill
With the truck in drive and the parking brake on, I turned on the A/C, lights and a directional. I then got 12.8 volts at the battery. This is significantly lower than normal, but with a 12 volt system shouldn't that be enough?
Old Mar 7, 2016 | 12:36 PM
Rusty_S's Avatar
Rusty_S
12.8V is the nominal battery voltage with no alternator output. 12.7V to 12.8V is what a battery should have fully charged with no loads on.
My truck I believe is like 14.2V at idle but I never checked it with things like headlights on or A/C on. Thing is though the voltage shouldn't change with load the amperage is what should change. Unless I am thinking incorrectly on it but the alternators job is to provide more than 12.7V to run the vehicle as well as maintaining the battery. Then the battery is used to remove ripples from the charging system since an alternator produces A/C current which when rectified via a rectifier bridge results in not a smooth DC pattern.
I personally could idle my truck up some as its right above 500 RPM with A/C on its right on 500 RPM, but the thing is though when idled up the brakes really make you work on stopping at the level I have it at now it stops great. Can actually lock the wheels up pretty easily. this is why I would go upgrade route with a 3G vs idling the truck up.
Old Mar 7, 2016 | 01:13 PM
roadrash63's Avatar
roadrash63
You should have at least 14.5 volts at idle.
If you don't know something is wrong.
Check your belt tension. Idle speed should be set to factory specs. Check your electrical connections at the alternator and voltage regulator if you have an external one. Failing that take it to an auto parts store and have them run a full system test on your electrical system there is usually no charge at Advance Auto.
