Fordguy2100's Hoosier build thread
Old 09-12-2017, 10:55 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Your cat is a bad *** for sure. That green tractor brings back some miserable memories. My dad was quite enamored with green tractors with flywheels hanging off the side. Learned to drive on a 330.
I'll check that green highboy for d shafts too.
  #47
Old 09-12-2017, 11:03 PM
grinnergetter
Grabbed the dang flashlight and checked. Everything you need is on that green truck. Everything.
  #48
Old 09-14-2017, 09:10 PM
fordguy2100's Avatar
fordguy2100
fordguy2100 is offline
Lol yeah my next tractor purchase will be an electric start for the days that dang thing don't wanna start by hand pull starting > throwing the flywheel a million times
Awesome! I'll shoot you a text
  #49
Old 09-29-2017, 05:31 PM
fordguy2100
Got the dipstick tube reinstalled in the oil pan, hopefully getting some time this weekend to get the oil pan installed then I'll fire her back up and make sure all my leaks are gone... well minus the major bendix steering assist leak that probably isn't going away any time soon. Finding Driveshafts and Rust repair are still on the schedule thru this winter
  #50
Old 10-05-2017, 08:55 PM
fordguy2100
No time for the oil pan this weekend but picked up the rims I've decided to run on the Highboy! can't wait to get some 37s around them
  #51
Old 10-06-2017, 12:17 AM
meangreen92's Avatar
meangreen92
meangreen92 is offline
Nice truck, and cool thread! Those wheels are going to look good on there.
  #52
Old 10-06-2017, 08:57 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
Yes they are going to look good.
  #53
Old 10-06-2017, 09:40 AM
SlikWillie's Avatar
SlikWillie
SlikWillie is offline
I would clean them with Superior Aluminum Brightener from Oreilly's. A gallon cost $11 and your wheels will literally look brand new. Just follow the directions.
  #54
Old 10-07-2017, 12:26 AM
fordguy2100
Thanks and I cannot wait! Already started pricing tires but with winter approaching they wont go on before spring I suspect. Still got Work to get done just couldnt let these pass! I decided a while ago those were the rims I wanted but kept my hopes from getting up, didnt think Id find any close by or for a reasonable price.
Thanks again! I was telling Ed I hope to make it out to the swap meet sometime; sounds like a fun weekend! (Well for me anyway, the wife would be bored...) maybe send her on a girls weekend with her sisters and I will bring a few buddies down!
Hmm I’ll look into that thanks! This is my first time with aluminum wheels so I will be researching the best way to clean and care for them.
  #55
Old 10-07-2017, 10:40 AM
77&79F250's Avatar
77&79F250
It is a very busy 3 to 4 weeks loading the trailer before it all happens fun weekend., me and Ed are already planning on doing it again next year.
That might be the year I bring it all and sell out.....
  #56
Old 10-09-2017, 04:49 PM
fordguy2100
My local oreillys didn't carry that stuff but Napa did. Picked up a gallon and was quite impressed with it. I'm going to need to put some elbow grease in to make these look perfect but for just spraying with the acid and then hose, stuff worked great!
Edit* I had them in nice before/after comparisons but for someone reason the mobile app doesn't upload them in the order I choose
  #57
Old 10-09-2017, 04:54 PM
SlikWillie's Avatar
SlikWillie
It's some awesome stuff, ain't it. I used it when I worked for a trucking company in high school. Made those big wheels and fuel cells look real good.
  #58
Old 10-10-2017, 02:00 PM
fordguy2100
Well didn't see this being an issue I've seen so many Highboys running these rims... did they make them in different offsets? Also What's the best way to measure for rim size? I thought they were 16.5s but they seem to match up with my current 16s
  #59
Old 10-10-2017, 04:20 PM
77&79F250's Avatar
77&79F250
I think the rim to steering knuckle issue is because you have a D44 closed knuckle, low pinion, Bendex steering set up axle. Primarily because a closed knuckle axle is different than a open knuckle axle. I am pretty much guessing at this point.
Like I said over the phone, I will work it get them back and give you a full refund.
Rim to rim they can match the 16", but 16" tires will NOT fit for sure. Outside edge to outside edge measurement will be off, because 16.5 have a extra bead of some sort.
  #60
Old 10-10-2017, 04:29 PM
meangreen92
Aw, I was wanting to see them holding a truck to its tires.
Quick Reply: Fordguy2100's Hoosier build thread
