Fordguy2100's Hoosier build thread
#318
Quick update. Got the axle torn down and cleaned up. Bearings are in. Things to do still: clean up backing plate/wheel hub, order brakes and seals, and paint. Sadly the Eastwood ceramic paint I was going to use is on back order until mid March. Not sure if I can wait that long lol.
Next update will probably be when the axle is painted... so it may be mid March.
#320
#321
Hello!
I just saw your restore thread.... I have really enjoyed reading from the start.
My $.02 on the gasket thing..... I don't think you can beat a good cork gasket if you want to keep your rear diff cover dry.
In the past (while doing the old flat fender Jeeps) I used the gaskets and I put a coat of the Permatex black aviation sealant on both sides...... Jeeps are notorious for marking their territory..... LOL.
Any way.... no runs, no drips, no errors and nobody left on base.
Mike
Mike
#322
Originally Posted by Meridian_Mike
Hello!
Mike
Mike
#323
So got tired waiting for Eastwood to get paint back In stock. Decided to give rustoleum a chance. So stay tuned in the next couple years as I will update how it holds up. If it's crap, I'll do it again with Eastwood, if not I'll be happy it's done now!
So far I have the primer on, rear cover sealed, brakes are ordered, and 2 questions. 1. I've read a million recommendations for gear oil... what would be best for the rear diff. I live in the Midwest and get freezing winters and scorching summers. 2. What color should I paint the hubs? Since they stick out thru the rims, should I keep everything black? Or try to match the silver of the rims? Some quick crappy photoshops to show what I'm asking.
#324
I have always painted mine black. I can't remember what color they were originally..... (Mostly rust colored.....)
According to Superblue400's thread.... they were black from the factory......
https://www.ford-trucks.com/forums/1...ration-22.html
ME... I would go with black.
Mike
Mike
#325
#326
#327
As far as which gear oil to use...... I can't say.... I'm sure most will be more than sufficient for the job.
At one time, there was a list of Ford accepted oils and other fluids....
Maybe Numberdummy knows.
Mike
Mike
Originally Posted by numba1killa
Hey Mr. Ford guy, just wanted to say Hi and loved reading over your thread... you've come a long way!! Congrats on the little girl, and hope you and your wife are doing great
looking forward to seeing more progress,
Take Care!!!
numba1
Take Care!!!
numba1
#328
#329
Also after reading one of meridanmikes threads I saw he mentioned evaporust; he used it and became a believer and now I am too! Figured it was perfect to try on my hardware for the axle.
I HATE wirewheeling nuts and bolts to clean them up. You never get it all and you rip your fingers a few too many times. Can says to soak for 12hrs. I put them in about 3PM and took them out about 10AM the next day. 19hrs total but I check at about 6hrs and they already looked great.
