1948 f-6 Clutch assistance, too short?
Great, thanx. Any chance you could take a few pictures? I think my clutch ball Equalizer is not correct as seems too small in diameter and might not come as far out as needed (hence it falls off even with brass sleeves and spring). I've starting looking for a replacement to see, but hard to find:
Early Ford Store of Ca - Early_Ford_Parts New and Used Original Parts for 1928-1959 Cars & Trucks
http://www.collectorsautosupply.com/...section=CLUTCH
https://www.npdlink.com/store/?p=cat...arent=0&year=0
The part for the F1-F3 01y7507 is NOT the same part as the F4-F6 01T-7507A
NOS Parts LTD
2020 Shield Parkway
Waxahachie, Texas 75165
(972) 937-2201
www.nospartsltd.com NOS Parts Ltd is an independent parts warehouse that specializes in providing Obsolete New Old Stock Ford parts for Ford and Lincoln - Mercury cars and trucks.
Has 4 in stock. Perhaps you should do some measurements of the one you have and contact them to see if they can compare your measurements to the parts they have.
The collectors auto supply link does not work.
NOS Parts LTD
2020 Shield Parkway
(972) 937-2201
NOS Parts LTD
2020 Shield Parkway
(972) 937-2201
I removed the Clutch Equalizer ball piece and will clean it up tonight to see if there are any markings on it. It appears to be the correct 3 hole part. But the diameter on the ball is more like 3/4". So either the piece that goes on the ball socket (with sleeves and spring) is slightly short in length, or the equalizer ball is incorrect. Someone might have used a combination of F1 parts...
OK, well it looks like that is the correct part, even if it is worn, with the spring and shims it should not have that much of a gap. The arm from there to the clutch is the same part for the F1 thru F6, so that should not be the problem, so perhaps it's time to step back and look at the overall picture.
1. Are the holes in the frame for this bracket elongated at all?
2. Is there another set of holes there, could the bracket have been moved?
3. Is the transmission crossmember correct and properly mounted?
4. Are the motor mounts correct (original) and properly located? (Engine/transmission offset?)
5. Is the frame bent anywhere?
#28
#29
#30
