Cracked Pass Side Up Pipe Needs Replacing
Old Mar 3, 2016 | 08:25 AM
651_F350_KR's Avatar
651_F350_KR
Found out my up pipe on my passenger side has a crack right at the bellow, looks like its the top, and it has been rattling like an SOB. Looking at ordering the sinister diesel passenger side up pipe to replace the cracked OEM one. I've seen two ways to go about removing this, either pull the turbo or pull the down pipe. I have the stock 3.5" down pipe and would like to avoid cutting it to get it out, is that possible? Otherwise is there anything to know about pulling the turbo?
Any input on how to go about this would be great.
Old Mar 3, 2016 | 08:33 AM
jimmyv13's Avatar
jimmyv13
This guy rebuilt mine:
https://www.ford-trucks.com/forums/1...pe-repair.html
Old Mar 3, 2016 | 09:46 AM
651_F350_KR
Originally Posted by jimmyv13
I may look into sending him the one I pull out. As for getting it out, did you pull your turbo?
Old Mar 3, 2016 | 10:16 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Removal without removing turbo or downpipe (remove band clamp only):
https://www.ford-trucks.com/forums/7...tructions.html
Old Mar 3, 2016 | 10:37 AM
651_F350_KR
Thanks, I've bookmarked this for when I dig into it. Looks like they disconnect the dp from the rest of the exhaust then undo the clamp at the turbo and just kind of shove it to the side?
Old Mar 3, 2016 | 11:56 AM
jimmyv13's Avatar
jimmyv13
I did the repair at the same time I had the turbo out.
th3_d0c
Dec 30, 2016 10:14 PM
wingrider75
Jun 19, 2015 10:04 AM
bio-d
Aug 6, 2013 03:29 PM
old-rodder
Jun 11, 2013 05:11 PM
bkuuz1
Apr 26, 2010 10:24 AM
