Sponsored by: Real Truck
help!!
Old Mar 2, 2016 | 07:26 AM
andyfigz's Avatar
andyfigz
help!!
I have a 06 E350 SD diesel 6.0
I ran out of fuel and now that I refueled it won't start up...
Anyone able to help me get this started?
Old Mar 2, 2016 | 07:31 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Is it a gas or diesel?
Coronado's Avatar
Coronado
Is it diesel?
Old Mar 2, 2016 | 07:34 AM
sxrfun's Avatar
sxrfun
First off we need to know what engine you have in the truck? I'm going to assume it's the 6.0 liter diesel? If so you'll need to bleed all the air out of the fuel system, which can be a bit of a pain. I'm not exactly sure how to do this on a 6.0 liter so hopefully someone that is chimes in.
m-chan68's Avatar
m-chan68
I will be the 3rd to chime in with the same question. Gas or diesel?
Old Mar 2, 2016 | 07:38 AM
m-chan68's Avatar
m-chan68
Negative on that. If it is a 6.0L diesel, one or at most two key cycles should get the vehicle started once fuel is added. If this were an F-Series with the 6.4L or 6.7L on the other hand, it would be a different story. Those 7.3L and 6.0L engines are a little more forgiving for instances like this than the newer ones (or any other diesel employing common rail injection for that matter).
But let's first let the OP chime in with more information before we go any deeper.
Old Mar 2, 2016 | 07:53 AM
sxrfun's Avatar
sxrfun
Ahhh...learn something new each day
Old Mar 2, 2016 | 09:10 AM
andyfigz's Avatar
andyfigz
Its a Diesel...
Old Mar 2, 2016 | 09:34 AM
andyfigz's Avatar
andyfigz
Originally Posted by andyfigz
Its a Diesel...
Its a Diesel 6.0
Old Mar 2, 2016 | 09:56 AM
wrvond's Avatar
wrvond
Just turn the key to ON and listen to the pump run. It will stop after 20-30 seconds, then turn the key back to OFF and back to ON again and let the pump run again until it shuts off. Twice is usually enough but you might as well do it again for good measure. The bowl will be full and it should start.
If it doesn't start, open the bowl-drain valve and you'll probably hear and see air escape, close the valve and cycle the pump a few times again it should start then.
Old Mar 2, 2016 | 09:59 AM
nmclella's Avatar
nmclella
Running out of fuel is hard on injectors - hopefully you didn't cook any.
Old Mar 2, 2016 | 10:21 AM
andyfigz's Avatar
andyfigz
Thanks everyone...
Will try to see what happens
Old Mar 2, 2016 | 03:13 PM
allagash350's Avatar
allagash350
Running low or out of fuel on a 6 liter can also cause clogged filters.
When it runs low the fuel intake can clog with debris from inside the tank.
If you can't get it started you might need to drop the tank and check
Old Mar 3, 2016 | 02:08 PM
EDC8008's Avatar
EDC8008
Had filters on mine changed in Kansas a few years back, watch the filter seals if you had them out. 4 hours to get it started. They ordered a new filter and seal 3 cycles with the key an undugaduga, off I go.
Jnm2359
Mar 28, 2014 02:10 PM
Kenneth A
Dec 17, 2007 08:55 PM
powerstroke6ltr
Jul 11, 2005 08:07 PM
jimdc8
Mar 7, 2005 06:06 PM
zeindog
Car/truck Buying Advice
Sep 7, 2002 09:25 PM
