'95 Explorer code-what does it mean?
Old Aug 11, 2003 | 10:49 AM
southy7's Avatar
southy7
I recently had my '95 Explorer Limited Ed. hooked up to a machine at the local auto parts store and it came up with a code #632 trans control switch? What does that mean and what do I need to do?
Thanks!
Karyn
Old Aug 11, 2003 | 11:52 AM
marragtop's Avatar
marragtop
My code manual says 632 is 'Overdrive Cancel Switch/no action during engine run self test'. When you are running the test, you need to engage/dis-engage the OD button. If the person running the test didn't do that, it will give a 632 error.
Mike
Old Aug 11, 2003 | 12:10 PM
southy7's Avatar
southy7
Thanks for your reply....
My OD on/off is not working...it stays in the "off" position plus my speedometer is acting crazy and it goes into gear hard...it overworks itself so I had to drive it in second gear for it not to do that
Old Aug 11, 2003 | 12:32 PM
marragtop's Avatar
marragtop
Sounds like your transmission(assuming you have an automatic) may be in 'cripple' mode which is not good for it. Have you tried unhooking the battery for at least 5 minutes to clear the codes? This may help.
Mike
Old Aug 11, 2003 | 01:02 PM
southy7's Avatar
southy7
Thanks! I haven't tried that yet..
Karyn
