1978 - 1996 Big Bronco
oil pressure
Old Aug 11, 2003 | 10:18 AM
mtm1972's Avatar
mtm1972
oil pressure
So I've read about what to do about low oil pressure readings from factory gauges. I hope the gauge is my only problem since the bottom end was replaced on my 1988 5.0 only 10,000 miles ago. My question is, how do you avoid having the factory gauge trigger the engine light? Thanks!
Old Aug 11, 2003 | 01:25 PM
89Bronco_EddieBauer's Avatar
89Bronco_EddieBauer
oil pressure
What do you do about low oil preasure readings from factory gauges???
Old Aug 11, 2003 | 02:07 PM
mtm1972's Avatar
mtm1972
oil pressure
Basically, I read that they are highly inaccurate and that you should replace the sender with a manual aftermarket gauge. Mine registers zero after warm up even though I've replaced the whole lower end AND put in a high pressure oil pump.
