6.0 fuel problem
Old Feb 28, 2016 | 04:22 PM
Cityguy13's Avatar
Cityguy13
6.0 fuel problem
I have a 2004 f350 that wasn't getting enough fuel pressure, so I changed the pump and now I'm not building any pressure at all, not even at the hfcm. Don't know what to do...
Old Feb 28, 2016 | 04:43 PM
Per4mance's Avatar
Per4mance
How did the filter look when you pulled it out? Do you have the filter in right and not crunched?
Old Feb 28, 2016 | 07:03 PM
mhoefer's Avatar
mhoefer
So when you take the top filter out and someone turns the key to on, the top bowl is not filling? That probably means the bottom filter is not in correctly and opening the bypass? Does it run with key on, you should easily hear it....
Old Feb 28, 2016 | 07:19 PM
devils toy's Avatar
devils toy
When you put the new filter in did it have a thick oring around the pump? That separates the hfcm to build pressure without it , its just swirling fuel around.
TSupanik
Apr 23, 2021 08:26 AM
dgulledge
Jan 4, 2015 09:09 PM
JOHNSHO
Oct 11, 2011 05:56 PM
priv8pilot
Jul 13, 2006 07:54 PM
daves93aerostar
Aerostar
Jul 13, 2004 08:28 PM
