Backup Sensor
Old Feb 27, 2016 | 10:11 PM
aero993's Avatar
aero993
Question Backup Sensor
Hello,
As soon as I put my truck in reverse, the alarm goes off even if nothing is near me. This just started a few days ago/
Thanks
Old Feb 27, 2016 | 10:41 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Sometimes it's as easy as just cleaning the sensors with a cloth.
Old Feb 28, 2016 | 09:07 AM
jhcorley's Avatar
jhcorley
One of the sensors has gone bad. Have someone put it in reverse without engine running, with brake applied and listen to each sensor. They each emit a "ticking" sound when working correctly. Just had the same issue with mine and had to replace a sensor.
Old Feb 28, 2016 | 09:37 AM
Drunken_Unicorn's Avatar
Drunken_Unicorn
I have had mine get stuck on before. I wiped the dirt of of the sensors and all was well. The exhaust steam when starting Stan on the colder mornings sometimes sets the reverse sensor off too.
Old Feb 28, 2016 | 10:02 AM
DidieX's Avatar
DidieX
I have this problem in the rain and snow sometimes. As mentioned above, a quick wipe of each sensor will usually clear it up. If not, you can use a Bluetooth obdII dongle and the forescan app to check the module, it'll give you a code for the sensor that is not working.
Pyancey
Jan 16, 2013 09:08 PM
tbsexc
May 26, 2012 08:56 PM
Whysobig?
May 31, 2011 10:34 AM
watchdog 1
2004 - 2008 F150
Oct 26, 2007 03:22 PM
0RangerEdge2
Apr 9, 2007 07:32 PM
