1997 Expy EB
Old Feb 25, 2016 | 10:58 PM
Ecko1981's Avatar
Ecko1981
1997 Expy EB
I bought a 1997 Eddie Bauer
Found out the rear end was **** ... Replaced it due to the rear end grinding after 120 miles of owning it.
Took it in had it replaced.... Put on about 100 mikes and its doing it again... But only at low speed till it shifts out of First gear type of speed...
What else could be the issue and I didnot replace the rear trailing arms and am wondering if it ccould cause this issue as well.
Live this rug otherwise bit would like to be able to drive the family around safely
Old Feb 26, 2016 | 04:54 PM
CycleVIN's Avatar
CycleVIN
Sounds like its your transmission not your rear differential. If it was your rear diff, the grinding sound would be audible all the time. If the grinding is only in first gear and not in the other 3 gears, then it sounds like you need to have first gear replaced/repaired in your tranny.
Old Feb 27, 2016 | 04:38 PM
alloro's Avatar
alloro
Could also be the transfer case if it's a 4WD. I would hope the garage would've diagnosed this first before replacing the rear end.
F150Texan
2004 - 2008 F150
23
Apr 19, 2006 08:44 AM
sanford
Mar 19, 2006 12:25 AM
rhollier
1997 - 2003 F150
Apr 11, 2000 03:42 PM
