Electrical PLEASE HELP!
Old Feb 23, 2016 | 07:22 AM
mrgrimm's Avatar
mrgrimm
I'll try to remember to bring home my wiring schematic book from work today... it's for 2000 model year super duty/excursion but should be similar. I believe your truck uses a GEM (generic electronic module) located behind the interior fuse box...the GEM controls many if not all of the interior functions you mentioned were acting up.
There is a spot where wires go through the firewall on the driver side, above the PCM, and a cover should be in place, but on one of our work trucks that cover was missing and water intrusion caused some corrosion on the connectors at the back of the fuse box...just something you might want to check.
Old Feb 23, 2016 | 09:17 AM
dkrimetz's Avatar
dkrimetz
Thank you for the heads up! I'll have to take a look at the GEM module. Forgot to check that. As for the door wiring, I pulled the boot back yesterday and all looked good.
Old Feb 23, 2016 | 10:02 AM
Shepherd2's Avatar
Shepherd2
Don't think they had a GEM in 02, now it's the VSM behind the radio. As for the soldering, any computer or cell repair shop can reflow those parts for maybe $30.
Old Feb 23, 2016 | 10:06 AM
dkrimetz's Avatar
dkrimetz
Ok didn't even think about that. Is that essentially what they do to repair those parts when you send it in to that shop on the East Coast?
Old Feb 23, 2016 | 10:11 AM
Shepherd2's Avatar
Shepherd2
Pretty much. Shops may claim there's more to it to try and convince you to send it to them but as you saw in that thread it's not rocket science.
Old Feb 23, 2016 | 12:58 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
@shepherd. You sound pretty hip on the systems, any idea what caused the fuse to blow and how or why it correlates to his battery-alt issue ?
Old Feb 23, 2016 | 01:38 PM
dkrimetz's Avatar
dkrimetz
I checked with a local computer repair shop here and they said they couldn't (or wouldn't) do it. I have limited computer repair shop options here and they said it would have to be done by machine. I call Bs, but back to the drawing board on that front.
Old Feb 23, 2016 | 05:22 PM
dkrimetz's Avatar
dkrimetz
Got home from work and started messing with the OD switch. Pulled the end off since I ordered a new one anyway and found two of the wires had nicks in the insulation. Though cool I'll keep the plug off, plug it back in, and try to see if them not shorting on the tube worked to keep everything up.
Batteries have been unhooked all night.
Started the truck with new fuse in #35 slot and everything was on and working perfectly. Thought "AWESOME" it was the switch the whole time. Wires were just screwed in the tube portion!
Tried the driver window switch, worked. Tried both the driver and passenger side, fuse blew. Unhooked the batteries again, replaced the fuse, hooked them back up, pulled the fuse, it was shot already. Put another fuse in, heard a click from behind the guage cluster as that fuse blew. Does this mean it is my battery switch and the only reason it worked was because the batteries were off over night? Thanks in advance.
Old Feb 23, 2016 | 05:30 PM
pirate4x4_camo
FTE Remembers
If I am following correctly it sounds like when you use the window switch the fuse blows ?
Old Feb 23, 2016 | 05:55 PM
killerstroke's Avatar
killerstroke
Sounds like a short in the interior lights to me, remove the cluster and unpin (or cut the wire if you prefer and fix it later) Pin2 of connector c220c Black/Light Blue wire. If the fuse still blows, it's in the cluster. If it doesn't it's a short in the interior light system.
Diagram and identification of the plug in this post:
https://www.ford-trucks.com/forums/1...-override.html
Old Feb 23, 2016 | 06:24 PM
dkrimetz's Avatar
dkrimetz
Ok I'll try that. I appreciate all of your input. Thanks!
Old Feb 24, 2016 | 06:39 AM
mrgrimm's Avatar
mrgrimm
One more thing, visually checking wire basically tells you nothing...the copper under the insulation can be corroded green, or even split in two and you would never know it!
Best bet is to find the ends at a connector, unplug, and check with a light that draws some current (I use a brake bulb with running light terminals soldered together to draw the most possible out of it). If the wire checks out good, then you can start to isolate by sending 12v power and ground with it plugged in/working switches, etc...
Sometimes a sewing needle comes in handy to probe in the middle of the wire somewhere to get a better idea where your problem may be, but can also give an entry point for moisture so choose wisely lol. Then either splice out that section or just overlay the entire thing.
My 2000 book will be no help if your truck uses the VSM, ran into the issue on one of our 04's and I was wondering when the change was made, like another member mentioned must have been around 02.
Old Feb 25, 2016 | 12:15 AM
  #28
dkrimetz's Avatar
dkrimetz
Since I've been slammed at work and my wife has been bugging me, I broke down and called Ford and brought it in to them. They charged me $135 and tested a bunch of the components for me and determined it's the cluster. :-( Already put my order In with CBM and should have the cluster out and shipped tomorrow. Thank you for all of the help but unfortunately, electrical just isn't my thing and I felt like I would be pulling more hair out. Figured for $135, it was worth it with my work schedule right now. I'll let you all know if it gets fixed once back and installed next week. Thank you for all of your help on this one, fellas!
Old Mar 1, 2016 | 01:39 PM
  #29
dkrimetz's Avatar
dkrimetz
So I got a call from Circut Board Medics today telling me they couldn't replicate fuse 35 blowing when they were testing my guages. That sucks. So I'm having them do the "preventative maintenance" and replace the parts anyway since they already have the unit and this seems to be a common problem at some point on these trucks.
Problem is, I thought this was going to be my solution and now it does not. My gut tells me there is a short since Ford tested the fuse block and it tested out ok. Someone also mentioned the GEM as a potential issue but not sure what that is or entails. Any additional odeas would be appreciated. Thanks!
Old Apr 6, 2016 | 04:04 PM
  #30
CircuitBoardMedics's Avatar
CircuitBoardMedics
dkrimetz,
We've been tracing this down further since the fuse didn't blow on our test stand or even on our test truck here. Have you replaced the bulb in the dome light recently by any chance or had any problems with the dome light?
