Bronco 5.8L acceleration issues
Old Feb 22, 2016 | 07:08 PM
wattspd's Avatar
wattspd
Hi Folks!
I'm at the end of my rope trying to diagnose an issue with my truck a 1990 bronco 5.8l with about 135,000 miles. It goes like this...
Start the truck cold and runs like a champ for about 3-5 minutes.
As the temp gauge rises the hesitation starts. As it reaches normal op temp it becomes predictable when it hesitates such as starting from a light or under certain acceleration loads. For example if on the freeway going say 65 it runs fine no hesitation or bucking. If I try to accelerate if falls flat on its face. Ease of the gas and feather it, it keeps me going. Going up a hill immediately causes the hesitation.
I have no codes in the system.
I have replaced the following parts in attempt to fix the problem... And some parts broke along the way while trying to fix the problem.
Egr & sensor
Erg tube
TPS
O2 sensor
Fuel filter
Fuel Pump
Spark plugs
Spark plug Wires
Cap & Rotor
Distributor
Battery & Cables
Alternator
Both catalytic converters
I have no idea what else could cause this issue. Please help guys
Old Feb 22, 2016 | 07:27 PM
Conanski's Avatar
Conanski
So you get the all clear 11 or 111 code?
Exhaust leak or anything that sounds like one?
What is fuel pressure?
Old Feb 22, 2016 | 07:41 PM
wattspd's Avatar
wattspd
11, No exhaust leak, 40lbs at the rail.
Old Feb 22, 2016 | 08:00 PM
MI02SVT's Avatar
MI02SVT
Is the timing correct
Old Feb 22, 2016 | 08:11 PM
wattspd's Avatar
wattspd
Yes 100% its correct.
Old Feb 22, 2016 | 08:27 PM
Lead Head's Avatar
Lead Head
Try unplugging your coolant temperature sensor and seeing how it runs once it warms up. It's the one with a two-wire connector.
Old Feb 22, 2016 | 11:54 PM
wattspd's Avatar
wattspd
Would it run different with it unplugged at temp?
Old Feb 23, 2016 | 01:54 AM
wattspd's Avatar
wattspd
The check light activated. No difference for the better.
Old Feb 23, 2016 | 04:15 AM
killerstroke's Avatar
killerstroke
You could replace the temp sensor, they are cheap and I have seen a lot of problems related to temp sensors. Or find the resistance chart for the sensor and check it when warmed up, don't have the chart handy.
Old Feb 23, 2016 | 06:20 AM
Lead Head's Avatar
Lead Head
Plug that back in, and try unplugging the air temperature sensor on the intake manifold. It looks similar to the coolant temp sensor. If no change again, try unplugging the MAP sensor.
I know having you do this sounds goofy, but the computer will generally substitute a value that works good enough when you unplug sensors.
Old Feb 24, 2016 | 12:24 AM
wattspd's Avatar
wattspd
I replace all the vacuum lines and the temp sensor. It didn't help. Infact I think it might have made the problem worse. Maybe its just me. I'm at a complete loss right now.
Old Feb 24, 2016 | 08:35 AM
Conanski's Avatar
Conanski
What do the plugs look like?
Old Feb 24, 2016 | 11:43 AM
wattspd's Avatar
wattspd
I pulled a few and they look fine. Brand new top of the line plugs.
Old Feb 24, 2016 | 02:19 PM
Deuce40s's Avatar
Deuce40s
Have you replaced the ignition coil? See my thread I just bumped, that coil can cause some funky problems.
Old Feb 24, 2016 | 02:54 PM
TexasGuy001's Avatar
TexasGuy001
What does top of the line plugs mean? If they are Bosch platinum 4 or another gimmick plug, switch to standard Motorcraft or Autolite.
