Thanks for the technical info. Robert made me a deal on all the crank pulleys he had so I should be able to make something work. Maybe a pulley set will present itself later but at least I can get the truck on the road in the meantime. I'll probably want power steering but I doubt I'll add AC. As always you guys are awesome. Thanks for all the help and knowledge. I may actually learn enough to contribute to the forum in the future!
You're welcome. Learn enough? Contribute as you wish. A personal experience here, an opinion there.
Yea, the small pulleys are water pump,
I also have a couple lower pulleys 3 belt one is size (1) is 7.1/16" the other I'd check Monday also a 3 belts.
Orich
Orich, heres a picture of whats running on my '72 f250 2wd. The water pump pulley is a double about 7 1/4" and a fixed fan. I haven't had a problem with over heating but I haven't been in stop and go traffic in the summer with this truck much.The crank pulley is a triple with an added AC pulley. The crank pulleys are actually smaller than the water pump pulley...under 7". You have some pulleys that looks like this?
As with a fixed fan you can get by with a 7.1/4" W/P size pulley. Where as with if you where using a clutch fan the W/P needs to spin a little faster for any city driving.
And in most cases, I only see one belt for the alternator when a clutch fan is used.
Some guys when switching to a clutch fan don't realize they need to use the smaller pulley and wonder why there having some over heating in stop & go driving. this was my point.
Hey I'm not sure if you got everything or what your missing but let me know I have 2 sets right now I believe one was from a 360 and one from a 390 but I believe both work for either...and which ever ones I don't use on my rebuild your more than welcome to just let me know!
Orich
Ok, got it. I'll probably stick with the fixed fan because thats what I have and I kinda like to keep it a simple as possible. I found a single pulley I had for the water pump but am still looking for a double pulley for that so I can run 2 belts to the alternator.
May be at 70-75mph if that, but the clutch fans do help milk out a little more mpg.
Orich
Ah, didn't know that would help mpg. I'm pretty sure I have a clutch fan from a 460 I'm slowing working on. Maybe I should change out for the fixed fan and go with your smaller water pump pulley. Did you have a chance to check what size the other crank pulley you have is?
Lower crank pulley has 3 belt pulley 7.1/4"
And the w/p pulley, I just removed from my motor 2belts 6.5/8''
And have another 2belt pulley that, I got off and engine from the junk yard with a clutch fan that is 5.7/8" that I got to flip.
Orich
I would be interested in a 3 groove lower pulley for a 3 bolt harmonic balancer if anyone has one..I have a dual groove W/P and ALT pulleys now.
How about using a GM Saginaw pump? Will I be able to us the 3 groove crank pulley?
And IM SORRY for the hijack!
I've still have a 3v belt crank pulley. The two inner v belt grooves fit the alternator & water pump 3/8" belt with the pulley OD of 6.3/4"
The one outer v belt groove takes a 7/16" or a 1/2" width belt, the Pulley has a OD of 6.0"
And a water pump two belt 3/8" pulley with a OD is 5"3/4" pulley these smaller ones are needed when converting to a clutch fan as the water pump needs to spin a little faster in slow city driving.
The harmonic balancer contains a single sheave pulley. FoMoCo offered single, double and triple sheave outer accessory pulleys that bolt to the balancer to add P/S and/or A/C
