Simple intereference engine question
Old Feb 16, 2016 | 03:58 PM
rob7.3's Avatar
rob7.3
If the cams are not timed properly then the valves would be smacking the pistons and do severe damage correct?
So if the engine will only start if you hold the gas pedal down and crack the **** out of it and it starts and dies with in a few seconds would not be a cam timing issue correct?
I am looking for confirmation that I have not gotten so old that I have gone stupid. I am leaning towards a fuel related issue but scratching my head at this point.
Fourth time I have done timing chains (on different explorers) and never had this issue before. Thanks for opinions.
Old Feb 16, 2016 | 10:13 PM
shorod's Avatar
shorod
Did the Explorer run fine before you installed the timing chains? Which engine are you working on? Have you double-checked and triple checked all the vacuum lines, intake air tubing, MAF sensor installation and wiring, etc. to confirm you don't have a large vacuum leak somewhere?
-Rod
LARIAT 85
83
Feb 15, 2015 07:31 PM
hooperdoski
30
Oct 19, 2012 04:07 PM
Riderman
34
Jan 11, 2010 11:01 AM
jamies460
Sep 9, 2005 12:26 PM
rmcgraw351
Sep 9, 2004 12:48 PM
