1978 - 1996 Big Bronco
intermittent spark
Old Aug 10, 2003 | 04:46 PM
Metallheadd's Avatar
Metallheadd
intermittent spark
Hey guys,
I have a 79 Bronco with a 400 and Im getting an intermittent spark problem. It'll be running fine and just die out, then it'll come right back again running fine. I put a new cap and rotor on it with no change. I did notice that the fairly new Magnetic pick-up moves a bit which dont seem right. I also noticed a small amout of oil on the sides of the bottom plastic part under the cap. Im thinking I may have a wiring problem or maybe that pick-up being loose. I know its definitly a spark problem cause I can smell the raw fuel when it quits and it sometimes backfires thru the exhaust. Any ideas?
Old Aug 10, 2003 | 05:01 PM
Rascal2k's Avatar
Rascal2k
intermittent spark
The most common wiring failures that I've seen with those symptoms is a loose ground on the dist. or loose wiring on the coil. Check those first.
Old Aug 11, 2003 | 04:39 PM
Metallheadd
intermittent spark
It seems it was a bad coil. Must of been getting hot and then missing a beat. Replaced the coil and the problem is gone.
Yee Haw!
Citizenrain
17
Jun 11, 2012 02:30 PM
dogmantra
Oct 19, 2010 08:25 PM
dirtybird96
Oct 16, 2010 04:23 PM
ptesmoke
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 4, 2008 12:45 PM
+massacre+
1983 - 2012 Ranger & B-Series
24
Jan 31, 2006 08:18 PM
