Draining Coolant Completley
Old Feb 15, 2016 | 02:57 PM
Eddie C's Avatar
Eddie C
Can anyone tell or show me where to drain the coolant from the block on a 95 F250 4x4. I know where to drain the radiator but am unsure of the block.
Any special tips on performing a good flush would also be appreciated.
Old Feb 15, 2016 | 03:37 PM
madpogue's Avatar
madpogue
There are two block drains, one on either side of the block. Driver's side is near the oil cooler (forward of it), passenger side is kinda obscured by the starter. I usu. pull the starter to get to it.
Most commonly referenced flush procedure is this one: Coolant changing instructions... - Diesel Forum - TheDieselStop.com . Based on an SD, but most of it applies. The only real difference would be the selection of anti-freeze. It's been said that the injector sleeves in our generation of truck are not compatible with ELCs. So a plain "green" old-school ethylene glycol anti-freeze and the appropriate amount of SCA would be in order. The other option would be FleetCharge (NOT FinalCharge, which is ELC, and NOT FleetGuard, which is a brand of SCA, but FleetCharge) anti-freeze, which is old-school EG with nitrite SCA added. The base anti-freeze is the same as the old "green" stuff; this just happens to be dyed pink.
Old Feb 15, 2016 | 09:21 PM
Bob_T's Avatar
Bob_T
...The other option would be FleetCharge (NOT FinalCharge, which is ELC, and NOT FleetGuard, which is a brand of SCA, but FleetCharge) anti-freeze, which is old-school EG with nitrite SCA added.
I went through a pretty thorough and confusing coolant study exercise when I first bought my 7.3L. It turns out there is a FleetGuard series of coolants in addition to their FleetGuard brand of SCA additive. The coolant I used is FleetGuard ES Compleat which is an ethylene glycol coolant pre-charged with SCA4 additive. It's dyed blue.
Here's a link to Fleetguard coolant, which is a Cummins product, hope that's OK...
https://www.cumminsfiltration.com/pd...es/LT36237.pdf
Old Feb 15, 2016 | 11:34 PM
madpogue's Avatar
madpogue
The ES products on that ^^^^ page are all extended-life coolants. Again, what I've _read_ is that they're not appropriate for our engines, because of the injector sleeve material (which was changed with the SD engines). Interesting, I see even FleetGuard has an entry in the "old-school with SCA added" market, called FleetCool. And Ryder Fleet Services has it for only $13 / gallon, which is cheaper than the typical full-price retail for FleetCharge. I sorta wish I knew about that before doing all our three trucks with FleetCharge; FleetCharge only has nitrite as an SCA, whereas FleetCool has nitrite and moly.
Old Feb 16, 2016 | 12:24 PM
Eddie C's Avatar
Eddie C
I plan to pick this coolant up at my local Napa here in North Texas. This coolant was also recommended by another contributor. Is this the product you are referring to?
http://www.napaonline.com/napa/en/p/...003_0006545521
Thanks for the help. I'd like to get this right the first time.
Old Feb 16, 2016 | 12:42 PM
madpogue's Avatar
madpogue
That's the stuff. Do you have an Advance Auto nearby? Best deal on that FleetCharge - order online for in-store pickup, if you get four gallons it's over $50, enter discount code TRT30 and it's 30% off, no shipping charge, takes it down to about $11-12 / gallon.
Old Feb 16, 2016 | 07:24 PM
Eddie C's Avatar
Eddie C
I do have an Advanced Auto about 5 minutes away. I plan to look at the video and give this a shot by Friday..
I appreciate the help. Thank you
Old Feb 18, 2016 | 08:26 AM
Eddie C's Avatar
Eddie C
Good morning. I'm getting ready to do my coolant flush and think I understand Gooch's instructions well-enough to do this as a first-timer. A couple of things I want to ensure are correct: first, the block drain-plug on the driver side seems to be a 1/4" hex wrench, while the plug on the passenger side is different, not a hex and larger, I couldn't get to it with the starter in the way. Starter looks like its attached with three bolts which seem fairly easy to remove. Second thing is that looking through my refill capacities, my manual calls for 29qts but then on the first page has an "update" which calls for 22 quarts. I assume the 22qts is correct since it is an update which will lead me to use 5.5 gallons of new fluid broken down into half or 2.75gallons of Fleet Charge "Fully Formulated" coolant and half or 2.75 gallons of distilled H20. I assume my refill can be done through my degas bottle?
Old Feb 18, 2016 | 02:44 PM
madpogue's Avatar
madpogue
The drain plugs are often not the same side-to-side; you never know what was broken, lost, stripped, whatever over the years and what it was replaced with. I think I have different drain plugs side-to-side on all three trucks.
As for capacity, what year is your truck? Oh wait, never mind, you mentioned "degas bottle". So you DON'T have a '94.5 or early '95. In that case, the capacity is 8 gallons (32 quarts). And yes, you fill the system via the degas bottle.
Old Feb 18, 2016 | 02:59 PM
Eddie C's Avatar
Eddie C
My truck is a 95 F250 4x4 long-bed. I got under there today and I couldn't get the plug out with my quarter inch extension on driver-side. I sprayed with penetrating oil and will try again later today. With the 8 gallons, is that half (4 gallons) Fleet Charge and half (4 gallons) distilled water? The Gooch link recommended filling with 4 gallons coolant first then topping off with distilled water; I just want to make sure I'm doing this right.
Thank you
Old Feb 20, 2016 | 10:38 AM
Airstreamer67's Avatar
Airstreamer67
Yep, that sounds right.
Old Feb 20, 2016 | 01:38 PM
Bob_T's Avatar
Bob_T
Thank you
Yes, I think that's what Gooch had in mind. His philosophy is to fill with coolant first, then add water to top it off. That way you're sure of getting the full 4 gallons of coolant in the engine and if it won't hold the whole 8 gallons you're erring on the safe side with more than 50% pre-charged coolant. If you add 4 gallons of water first, you will likely not be able to add the whole 4 gallons of coolant. Likewise if you pre-mix it, you will likely have some left over coolant that didn't get into the engine. In the real world it probably won't make a significant difference but we might as well strive for excellence and perfection
Old Feb 20, 2016 | 01:47 PM
Bob_T's Avatar
Bob_T
This coolant stuff is confusing. I used the Fleetguard ES Compleat based on advice from Dale at Tymar Performance who is supposed to know something. And, I see that Fleetcharge specs don't call their Fleetcharge product an ELC (Extended Life Coolant) they call it FFL (Fill For Life). I guess there's some semantic difference that makes FFL acceptable and ELC isn't.
Old Mar 7, 2016 | 10:32 AM
Bob_T's Avatar
Bob_T
Here is a question I sent to Cummins Filtration:
Is ES Compleat ethylene glycol coolant suitable for use in a 1996 F-250 7.3L Diesel? I have heard that some "extended life" coolants are not compatible with the injector cup material and may cause corrosion. Ford or Navistar reportedly changed the injector cup material in 1999 to eliminate this problem but it is supposed to still exist for pre-1999 7.3L engines.
Here is their reply. I note that he didn't specifically address the injector sleeve issue:
"ES Compleat would be a great coolant for your F-250. The Coolant contains a pre-charge of DCA-4 that will protect against. Liner pitting, scale & corrosion. By using phosphate/molybdate based inhibitor package."
Old Mar 7, 2016 | 11:25 AM
coreyallan01's Avatar
coreyallan01
I hate when they side step a direct questio like that ^^^^^^!!
